Gen 4 engine swapped into Prius v, now have death rattle
Discussion in 'Prius v Technical Discussion' started by Kentsommer, Jun 20, 2022.
  1. Kentsommer
    Kentsommer Junior Member
    Mid-Wisconsin
    Long story short, I finished a gen 4 swap into my ā€˜12v. On a short test drive, it got hot. But cooled off when I drove more gentle.
    Then I heard a pop noise, not a hose blowing off, but it comes up with a bunch of codes ( low engine power) was one I remember right now. I limped it the last two miles home, and it will not stay running, even in maintenance mode.
    I’m trying to get the video to upload or link.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,161
    6,316
    Texas Hill Country
    Are the coolant reservoirs still full? Coolant moving in both reservoirs?
  3. Kentsommer
    Mid-Wisconsin
    Yes and yes.
  4. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Wondering if the pop noise was a fusible link or fuse...like the one on your battery pack safety switch, or in the fuse box
  5. Tideland Prius
    16,559
    *Edited title for clarity*
  6. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Once those engines get hot it's usually over.
    Sounds like vacuum line blew off...
    But that wouldn't cause it to heat up.
    Gen 3. Terrible car when they get miles on them. All gas savings lost and lots of headaches when the bad things start happening.
  7. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    I second the vacuum line. Maybe the heating caused a backfire. I had the PCV and EVAP hoses blow in October of 21. I swore the sound was a High Voltage Short. Engine would not stay running.
    Ultimate cause was covered in TSB with an update to the EVAP software (And $750). The TSB may apply to you.
    jzchen likes this.
