Gen 4 Front Wheel Hub Assembly Replacement
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jeff-2017 Prius, Apr 20, 2025.
  1. Jeff-2017 Prius
    Jeff-2017 Prius New Member
    Vancouver
    Technology
    I have looked and cannot find instructions or videos for replacing the front hub assembly on my 2017 Prius. Only videos/instructions I have found are for gen 3 and earlier.
    Any ideas on where to find this information?
    Front left is in need of a replacement.
    Thank you for your help.
    Jeff
  2. Mendel Leisk
    40,456
    Might be something of use in this mishmash:
  3. Jeff-2017 Prius
    Vancouver
    Technology
    Thank you. It appears to have some information. I'll let you know if it was enough if I get stuck halfway through.
  4. a2058
    a2058 Junior Member
    47
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I did this for a gen2 long ago, I had to remove the whole steering knuckle assembly and then use a H-frame 20 ton press with a correct diameter arbor to get the hub assembly off. It was corroded in there pretty good, aluminum and steel with the winter salt on the road.
  5. Tande
    Tande Active Member
    521
    308
    Mich.
    #5 Tande, Apr 25, 2025
