Gen 4 High Watt Inverter for minimal appliances.
Discussion in 'Gen 4 Prius Accessories and Modifications' started by priusloc, Jan 28, 2024.
  1. priusloc
    priusloc New Member
    South Carolina
    2020 Prius
    L Eco
    Installing another 12v or connect inverter directly to the one.
    what is the traction battery?
  2. ChapmanF
    15,409
    The traction battery is the high-voltage one responsible for moving the car. Most commodity inverters want a 12 volt input, so you will not connect those to the traction battery, but instead to the 12 volt battery.
    People with higher power needs sometimes do connect a (less common, more specialized) inverter to the traction battery instead. If you think you might be one of those people, this is your thread: Electric power from a hybrid, connecting inverter to the high-voltage system | PriusChat
    priusloc likes this.
  3. priusloc
    priusloc New Member
    South Carolina
    2020 Prius
    L Eco
    Thank you for the explanation. Im going to do more research my friend.3
    Thank you for the explaining. Im going to do more research my friend.
