Gen 4 HV battery pack modules are welded to each other ????
Discussion in 'Gen 4 Prius Main Forum' started by jadziasman, Oct 21, 2016.
  1. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Don't know if anyone else has read this yet but Toyota might have made a drastic change in the way modules are connected in the HV battery pack in the Gen 4. Not sure if this is for both the NimH and Lithium battery chemistries.
    Here's what was in this article
    A look inside the new Prius hybrid system
    posted on autoblog two days ago:
    Electrical losses were also reduced: "Instead of joints put together with screws on bus bars and connection bars, we now weld them together,"
    If this sentence is about the battery pack, I don't like that at all! It might not be possible to swap modules in Gen 4 packs when the time comes to replace a failed module or two.
    #1 jadziasman, Oct 21, 2016
  2. MichelleStone
    MichelleStone Senior Member
    549
    817
    Mariposa, CA
    This might also help the reliability. It's a tradeoff, I suppose. I'm just glad they guarantee the battery for as long as they do. That won't always be the case, I'm sure.
    RCO likes this.
    49,847
    you can't fight progress. maybe by 2024, there'll be cheap battery swaps.
    RCO likes this.
  4. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    I think some of the failures was because of corrosion. I know there are a number of youtube videos of people taking apart the connections, soaking them, and putting them back together again for a cheap $10 fix to the dreaded hybrid battery failure issue in the past.
    RCO likes this.
  5. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    For 95% people this is a better solution.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Of course you could always "unweld" them if you really feel the need to tinker.:whistle:
    RCO likes this.
  7. Mendel Leisk
    39,023
    Maybe "welded" is a poor translation, "soldered" would be more to the point?? (Maybe, just speculating.)
    Still, it will make any DIY efforts trickier.
    #7 Mendel Leisk, Oct 26, 2016
    RCO likes this.
