Gen 4 TPMS Is it useless?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by MrLightRail, Jan 14, 2023.
  1. MrLightRail
    MrLightRail Junior Member
    26
    Oklahoma
    This is my 3rd Prii, and the TPMS system is frustrating!!! I get a low tire alarm, but it doesn't show WHICH tire is low. Am I not doing things right, not finding the screen that shows TP? Otherwise, this just a frigging useless idiot light.
  2. Mendel Leisk
    38,726
    Take a tire gauge, check the four tire pressures? That'll take what, 5 minutes? Or first, walk around the car, do any look low?
    There is a good thread for this stuff:
    Just need to vent... | PriusChat
    fuzzy1 likes this.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    It will not tell you which tire is low, so you'll have to use Mendel's method. Useless is in the eye of the beholder...
    My 2022 Venza shows the individual tire pressures, but I end up checking all four (plus the spare) with a tire gauge anyway...
    Fubar XIII likes this.
  4. fuzzy1
    10,170
    I don't see how this Gen 4 issue is any different than Gen 3 and Gen 2. They all work the same way, one overall idiot light without any indicator of which is low.
    Everyone ought to have a tire pressure gauge in the car, TPMS or not. Then finding the low tire -- or finding that all the pressures are fine, it is just a dead sensor battery -- is trivial.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Take a deep breath.......
    It is not useless.
    It WILL tell you when at least one tire has low pressure.
    That is way more useful than having no warning at all.
    Fubar XIII and AzWxGuy like this.
  6. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    You can see the individual tire pressures in the Toyota App (but I would still monitor them with a pressure gauge). The monitoring system is designed as an alert system.
  7. bisco
    49,490
    or connect an obd reader
  8. MrLightRail
    26
    Oklahoma
    It's just an idiot light....Other Toyotas show individual tires. WTH is it with them cheaping out on the Prius?
  9. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    Yeah, the amount of peripheral cheapness Toyota went to for the 2019's is ridiculous. I have a center screen, but it's really only good for the backup camera. TPMS that my 2015 Ram had individual tires? Nope on a 2019 Toyota.
  10. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    No individual tire pressures on the Toyota App I have.
    There’s no way to monitor tire pressure.
    Or, do I need Toyota App training?
  11. Doug McC
    1,004
    377
    Midwest
    2022 Prius
    With the Toyota App I have found It does whatever it wants. There are features Toyota keeps swearing I have, but don’t.
    Mambo Dave likes this.
  12. Fubar XIII
    Fubar XIII Member
    42
    27
    Metro Detroit
    In my experience - 1st with TPMS - it works fine once you've lost 8-10 PSI. That won't be enough to visually detect. Tire pressure gage to find the offending donut then get it fixed immediately (assuming you don't need to top off just to get it there).
  13. Mambo Dave
    641
    306
    2019 Prius
    L Eco
    Same with mine.
    On top of a full-sized spare that I'd rather never have to use, I now carry a plug kit. The archaic Toyota TPMS that doesn't show individual pressures on a 2019 when that was an easy feature on a 2015 American car at least notified me in time to plug two screws about two months apart from one-another - that and the plug kit saved my day each time.
  14. ColoradoBoo
    ColoradoBoo Senior Member
    963
    631
    Monument, Colorado USA
    Yep, my Toyota App in my iPhone, when I set it up (2021), would show all 4 tire pressures. But they did an "update" and doesn't show that anymore. So I just deleted the stupid thing....great job (NOT) Toyota!!
  15. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Most of us used Techstream in the past to see each tire, or OBD reader, and then I bought a TPMS reader is what I use now.
    Not sure if Techstream still works re: newer models including my RAV4HV, which also does not give you each tire unless you have a upper level trim you get that as an premium extra...sheesh.
