Gen 5 dynamic mirror indicator mod.
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Perfectpacman, Jan 15, 2025.
  1. Perfectpacman
    Perfectpacman Junior Member
    71
    United Kingdom
    2024 Prius
    ----UK----
    Did this today and the difference is phenomenal
    The LED standard mirror indicator is almost useless in daylight. Really unimpressed.
    Besides the scary part of prising the expensive mirror away from the clips, the rest of the job was 10 minutes each side.
    Fantastic kit from Ali Express with everything you need. The quality is identical to the original.
    Highly recommended
    On offer right now. £24.49 GBP
    I just found this on AliExpress:
    £45.35 | Car Turn Signal Light For Toyota PRIUS 60 Series 2023 Parts Daytime Running Light Dynamic Indicator Mapping Light Yellow Light
    https://a.aliexpress.com/_EuYnG7O
  2. priusdriver223
    82
    30
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I envy the fact that you have the EU spec, I really wish they had auto folding and mirror turn signal on the US market…what a bummer. Cheers!
    Perfectpacman likes this.
  3. NJW
    NJW New Member
    Philadelphia
    2024 Prius Prime
    XSE Premium
    Do we know for certain that these are not compatible with US Spec cars? Does anyone have direct experience? If there's light and a wiring harness in the mirror, it would seem logical that it would.
  4. priusdriver223
    82
    30
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, yea it’s confirmed not in the US model, there’s a whole conversation somewhere else on this forum about it, it’s much much more complicated than it seems to be. I myself even have taken off the mirror caps to check and found out you’re going to have to take off the entire mirror and try to wire it by tapping into the rear turn signal wires. Cheers!
  5. Perfectpacman
    71
    United Kingdom
    2024 Prius
    ----UK----
    Agree, you'd also need to remove the door panels etc too unbolt the mirror base itself.
    In the past, I've found removing the door panels inevitably causes rattles in the long run, so I always avoid it.
    -1- likes this.
  6. NJW
    NJW New Member
    Philadelphia
    2024 Prius Prime
    XSE Premium
    Oooh, yeah, that’s not going to happen. Thanks for the info!
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Did the same mod on my 2012 Prius Plug In. Quality kit that replaced the mirror covers. I went one set further and removed the actual glass mirror and placed a LED amber > symbol under the glass. Wiring was minimal and turned out excellent. Not willing to try on a new car with a unproven kit
  8. Hammersmith
    Hammersmith Senior Member
    1,886
    1,877
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Do you like the idea of pulling your dash out? lol
    It's not absolutely necessary to do the job, but it sure makes it easier. I did the job last summer. For the folding mirrors, you need to add wires to the power distribution box assembly inside the dash. The relays to run the folding motors are built into the PDBA. Then you need a new power window/lock switch for the drivers door(only $650 if you by the left hand drive version from a US dealership or $90 if you buy the right hand drive version and import it from Japan). You also need new side mirrors that include the motors and signal lights. I imported mine from Japan, but a person might be able to buy them in North America now as the Mexican Priuses come with them.
    Then there's the wiring. A lot of additional wiring.
    I made a few mistakes along the way and had to double order some things, but I figure I would've been around $750 into the project with shipping from Japan and without the mistakes.
