Gen II larger tires, not wider?
Discussion in 'Gen 2 Prius Main Forum' started by rwernst, Nov 19, 2009.
  1. rwernst
    rwernst Junior Member
    United States
    My odometer is off by about 5% reading high. I'm ready for new tires and wondered if I can go to a taller tire size and/or taller aspect ratio.
    2005 standard/base Prius with keyless entry thing. Stock alloy wheels, standard tires are 185-65x15, can I go to 195-65, or 185-70 (if I can find them)? Can I go larger?)?
    And yes, I know this will affect acceleration, but I'm not worried about that. I do NOT want to go wider as they tend to be more expensive (I'm on a budget), and usually will reduce my mpg.
    And I don't want to spend money on new wheels.
    Thanks!
  2. brick
    brick Active Member
    1,083
    78
    Upstate NY
    What are you basing your measurement on? When I compare my odometer readings to my GPS (Garmin) trip mileage after a couple hundred miles of driving the difference is negligible with the OEM tire size.
  3. Patrick Wong
    18,200
    6,479
    There are many tire size calculators on the web. Here's one:
    Tire Size Calculator - Discount Tire Direct
    Based upon that, you will see that the difference between 185/65R-15 and 195/65R-15 is ~2%. 185/70R-15 will be ~3% larger.
    Also, there's some variation between tire brands so not all 185/65R-15 will be exactly the same diameter and circumference.
