Gen II Rims for Winter
Discussion in 'Prime Accessories and Modifications' started by Canvasback, Mar 11, 2022.
  1. Canvasback
    Canvasback New Member
    23
    Detroit
    2022 Prius Prime
    Hi all,
    Keeping my eye out for rims for winter tires for our new '22 prime. Any reason not to go for Gen II rims (not tires, obviously)? I know they will fit (same specs as Gen III, but a couple lbs lighter). Both Gen II and Gen III wheels are 1/2" narrower than Gen IV/Prime.
    Is there anything to worry about with "older" alloy wheels vs ???
    There are currently a plethora of Gen II rims at salvage yards near me, and I can get them for $50 or less, and from what I've read they are a couple lbs lighter than stock Gen III or IV (If this info is wrong please correct me).
    Thanks!
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Welcome to PriusChat, about the best place on t'InterNet to learn all you'll ever need to know about your amazing Prius:
    As you might learn from previous posts, I have a 2009 Gen II (touring) which came with OEM 16" alloy rims. I fitted them out with some decent summer tyres (Sincera SN250 A/S), but for the winter months I've always used a set of steel rims I got from TireRack for about $40 ea. shod with a set of decent snow-tyres. Over the past 6 years I've used Blizzak WS80s (very, very good) and currently my car is wearing a set of Antares (studded snows). One disadvantage of using alloys in the winter is the salt and garbage with which they treat the roads here in the North East (New England) plays holy-hell with alloy rims. I hope this helps and I'm sure lots of other readers will chip in with their ideas! Good luck! ;)
    Canvasback likes this.
  3. Salamander_King
    Salamander_King Senior Member
    10,977
    8,880
    New England
    As we have discussed in your other "spare" thread, Gen2 OEM rims should work fine. If you can find decent shape ones for cheap to be used for winter tires, then yeah, go for it. I don't see a problem. I did not find any cheap OEM wheels for my PP, so I ended up buying aftermarket wheels with snow tires package from the Discount Tire. With all sales prices, rebates, price much, I ended up paying less than $50/rim or a total of less than $400 for 4 Michelin Xice3 tires and MB Icon (alloy but not forged) rims mounted and balanced and free shipping ~4 years ago for my 2017 PP. The crazy thing was that it cost less than buying a set of four aftermarket steel wheels from the same online store. Yeah, it's not the best-looking wheel in town, but it sure looks better than black steely. At the price I paid, I am not complaining. I am still using the same set-up for my 2021 PP now. So, it is holding well in NE heavily salted road for 4 winters. The key is to wash and clean the rims and tires very well before storing them in spring.
    #3 Salamander_King, Mar 11, 2022
  4. Canvasback
    23
    Detroit
    2022 Prius Prime
    Thanks guys.
    @WilDavis, thanks for the heads up on the salt corrosion factor. I have considered steelies as well. Kind of like the idea of a lighter wheel, but I know steel are not that much heavier.
    @Salamander_King, the deal you got sounds like "the right price.". I'll keep that in mind. Did that deal pop up in the fall?
    I was basically intrigued by the weight of the Gen II, but I know weight is not the end all.
    I really was just wondering if anyone thought there may be drawbacks to the Gen II s, for whatever reason. I actually think the Gen II wheel are pretty "bleh" visually (and Gen III for that matter as well), but they are light, and I figured being OEM stock they'd be pretty durable, but thought I should ask.
  5. Salamander_King
    10,977
    8,880
    New England
    I really don't think Gen2 OEM wheels have a negative effect on the car at all. When I was looking for my winter set of wheels, the first place I looked was eBay trying to find used Gen3 or Gen4 wheels. I think I did see some Gen2 wheels as well and considered them, but none were within the price range I got from the Discount Tire deal. Especially after adding tires and installation costs. Even the new steel wheels were over $50 at that time.
    I think I got mine in September but back then a deal like that can be had any time. Leftover winter tires were often sold at a bargain price in spring. I got a previous set of same size brand new Michellin Xice Xi3 tires from a local tire shop for ~$100 for a set of 4. The only thing is that it was before the pandemic and the war. There may never be a sale like that again.
    As for the weight, just for a reference point, here are the weight of the wheel + tire.
    • PP Stock OEM wheel + OEM Dunlop Enasave 01A/S tire: 30.3lb (tire 16lb, wheel 14.3lb)
    • Aftermarket Steel wheel + Gen3 OEM Bridgestone EP20 tire (full-size spare): 38.3lb (tire 17.42lb, wheel 20.88lb)
    • MB ICON alloy wheel + Michelin Xice Xi3 tire: 33.9lb (tire 16lb, wheel 17.9lb) note: Discount Tire page I liked above for this wheel has a spec for this wheel and it says the weight of the wheel is 16lb. Don't know for sure what real weight is.
    Tire sizes are all stock 195/65R15, the weight of mounted tire and rim was measured by the scale, but the tire weight was searched online from the spec on this model of tire and size, and wheel weight was calculated from those two numbers. In my experience, the MB ICON alloy wheel with 3.6lb more weight than OEM wheels equipped with Xi3 snow tires had no noticeable mpg or EV range reduction compared to OEM wheel and tire.
    #5 Salamander_King, Mar 11, 2022
  6. vvillovv
    vvillovv Senior Member
    3,785
    1,324
    NY
    As long as the gen2 wheels offset and hub bore are the same or close enough to the Primes you should be good - should be! I'd get the specs or measure or get one to test on the prime first.
    You can get the Prime specs in this thread along with enough info to know howto and what to measure on the gen 2 wheels you're looking at.
    Aftermarket Wheel Fitment Guidelines | PriusChat
  7. Canvasback
    23
    Detroit
    2022 Prius Prime
    @vvillovv, The Aftermarket Wheel Fitment thread is indeed a great resource.
    @Salamander_King, The weight you calculated for he PP wheel is interesting. I thought I read it is was more like 16+lbs (And our '22 came with the Toyo Nanos, perhaps because LE?)? And point taken on the deal you got... I won't hold my breath for someone to practically pay me to put new wheels and tires on our Prime.
  8. Salamander_King
    10,977
    8,880
    New England
    Yeah, I did not have the wheel without tires, so my calculation is based on the published tire weight of the spec. The OEM Dunlop tire weight of 16lb is from the Tire Trak site. The calculated OEM wheel weight of 14.3lb is indeed less than 16lb. If you do buy Gen2 OEM wheel, weigh it before you install a tire. My 2017 PP Premium (the equivalent of XLE now) and current 2021 PP Ltd came with Dunlop OEM tires. But 2020 PP LE was equipped with Bridgestone Ecopia 422Plus (made in Japan). I think Toyota uses any of three OEM tires in any trim. I have not had Toyo tires on my three different trims.
    Here is a list of lightweight 15" wheels I considered, but did not purchase...
    • Volk CE28 = 8 lbs (15x6.5) ~$450 very rare to find 5x100/ 9.1 lbs (15x7)
    • Volk TE37 = 8.8 lbs(15x6.5) ~$450/ 9.2 lbs (15x7)
    • SSR Competition = 8.8 lbs (15x6.5) ~$395 only in 4x100 / 9.2 lbs (15x7)
    • Enkei RPF1 = 9.8 lbs (15x7) ~$200 only in 4x100
    • Konig Heliums = 11.4 lbs (15x6.5) ~$85 only in 4x100
    • Rota Slipstreams = 12 lbs (15x6.5) ~$145 only in 4x100 / 12.9 (15x7)
    • Velox Apex Hyper = 13 lbs (15x6.5) ~$140
    #8 Salamander_King, Mar 12, 2022
  9. Canvasback
    23
    Detroit
    2022 Prius Prime
    @Salamander_King, the wheels you list are far beyond what I am willing to pay (other than the Heliums and I don't want to fuss with adapters). Aesthetics really is 3rd for us behind durability and efficiency, but thanks for the info. We are probably gonna put 20k to 30k annually on the car (who knows what new normal for remote/in person work is really gonna be), but I suppose if someone could convince me we'd save $1k on gas over 100k mi I would consider the investment. Maybe.
    If I do end up purchasing Gen II wheels, I will absolutely weigh them and share the info.
  10. Salamander_King
    10,977
    8,880
    New England
    Yeah, that's the thing about spending $$$ on lighter wheels, unless you are taking your car for racing. After seeing the price tag on those lightweight wheels, I figured there is no way to recoup the cost from the fuel saved. In fact, for many years, I never bought separate rims for winter tires for my daily driver. A local tire shop where I use to shop for tires had free winter change over service. I had tires dismounted and re-mounted twice a year for free. The MB ICON wheels are the very first wheels I purchased for my own car. But after having snows on wheels, I can now swap the tires DIY without making an appointment with the shop.
    MTN likes this.
  11. MTN
    MTN Active Member
    306
    275
    SB, CA
    each or total?
    because you can find near new Prius OEMs on this site's classified, or Craigslist/etc for $250/set - sometimes less even!
  12. Canvasback
    23
    Detroit
    2022 Prius Prime
    @MTN --each. $250 for a like new set would be great, but their not as readily available as you suggest, at least not in my neck of the woods.
  13. MTN
    MTN Active Member
    306
    275
    SB, CA
    Go for Gen IIs for cheap!
    #13 MTN, Mar 16, 2022
  14. Mendel Leisk
    38,990
    I'm pretty sure the 3rd and 4th gen rims are dimensionally identical; the tire sizes are the same. And I'm thinking gen 2 rims are also the same?
    What I'm currently using for snows on my 2010, fwiw:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
  15. ttou68
    ttou68 Active Member
    349
    206
  16. Salamander_King
    10,977
    8,880
    New England
    As turns out, when I checked the spec, Gen2 and Gen3 rims are the same spec and size, but they used different size OEM tires. Gen2 is narrower. And as you know Gen3 and Gen4/PP use the same OEM size tires but Gen 3 and Gen 4 rims are not the same spec/size. However, I believe all rims can be used interchangeably.
    Gen2
    Gen3
    Gen4 and PP
  17. Canvasback
    23
    Detroit
    2022 Prius Prime
    Thanks Mendel for to the suggestion. I've seen your setup, abs caps and all! My understanding is that Gen II &Gen III have identical rim width @ 6" and ET45, while Gen IV is 6.5" ET40, but that Gen lll & lV have 195 tires, and Gen ll has 185. One thing they all have in common is good looks (ha!). Thankfully my main concerns are durability, weight, and cost. I've even pondered the feasibility of going smaller diameter on the wheels with taller sidewalls ( to presumably drop unsprung weight and maximize mpg?) Given how many miles were gonna put on this thing, if I came across a really light 14" rim and if there was a decent lightweight 195/80/14 or so, we could probably keep the Odo artificially low for extended warranty! Would probably look like cartoon tires! Not sure what that would do to rolling resistance, though...
    Mendel Leisk and Salamander_King like this.
  18. Canvasback
    23
    Detroit
    2022 Prius Prime
    Welp, that'll teach me to start a post, go off doing something, then finish it without seeing if someone else has responded.... I see @Salamander_King has already said what I just posted regarding wheel/tire similarities and differences...
    Salamander_King likes this.
