Gen III - 12V always, hot rear outlet mod. 120w
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rrg, Apr 30, 2012.
  1. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I decided to add a 12V outlet in the rear hatch, no key needed to start car.
    I carry a mini 12v air compressor in back and I need to use it all summer long for the kids' bike tires and balls. I hate always running into the house to get the keys and then lean into the car to start it. Plugging the connector into the center console area is hard to reach.
    So for $7.99 with shipping and a 1" spade drill bit, which I had, I did this.
    Do a search on Amazon for
    "New Motorcycle Cigarette Lighter Power Outlet Plug Socket 12V 120W" $7.99. The wire eyelet's, 10mm fit right on the battery terminals after removing the nuts. No changes needed there.
    DO NOT DRILL to LOW the carpet will cover the outlet lid (see corner pic) and that makes it hard to use near the carpet. Measure twice drill once. Also check for clearance behind that lid, there are spots that will not fit if drilled off the area I did.
    It will also be great for a future 12V spot light.
    Enjoy.
    Montgomery, sadie72, mrbigh and 2 others like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Great idea... too bad I got a sub-woofer in there.
  3. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Very smart ...
    But a few things you may want to consider:
    1. Unless the plug has it built in I would make sure to put in a fuse more or less 10A (matching 120W). Anything shorting the battery could be devastating ... (like even melting wires etc ... and surely damage the battery)
    2. Also running anything even accidentally off of the battery like spot light too long, could put you in a really bad situation ... like not be able to start the car ... the battery is about 35Ah which is about half of average. If you know this already stop reading... So running anything off of it without starting and then putting the car in Ready, you risk depleting the battery...
    I agree this is a very cool place to have a 12V outlet (but anyone in your family (or whoever) ever going to use this should understand the above). No problem doing this if the car is on Ready and in Park for example ....
    3. On the plus side this will actually help jump-start the car ... you would only need to put a cigarette lighter 12V stuff there (like a drip charger to start the car ... Prius only need what 10A max that is the good news)
    Just to consider ......
    Cheers
  4. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Yes, good point on telling the other driver (wife) about the long term use. If she were to use it I will insist on her running the car at all times.
    I really only require this in the summer for minutes at a time and my long term goal is to update the battery to the optima in a year or two, very early to mitigate the chance of having an unexpected dead battery. I don't want anyone ever having to jump this car but a trickle charger in a long cold winter is a good idea or I can use it for a solar panel :)
    It's a driveway parked car at home.
    Thx.
    The fuse is include and the future light is for emergencies.
  5. szgabor
    993
    175
    Oceanside NY
    Good thinking ... so you already knew ...
    This is a good way to integrate some type of trickle charge, especially if the car is not driven on a daily bases....
    On the upgrade to Optima you should read the many posts related to this ... it is ONLY make sense (to me) in very specific use cases ....
    I can explain, in details if you wish let me know, but "average" prius use you will waste your money ... :-(
  6. szgabor
    993
    175
    Oceanside NY
    Let me tell you just ONE story ... my wife decided to "beautify" the car wash clean whatever ... it was on ACC for the radio so the "ENGINE " will not come on ... (not realizing the the cabin fan was on as well) so the battery WAS depleted ... but I figured what happened and had a battery charger to connect to the "jumper" port for a little while and we did not need the tow truck...
    This is a real possibilty !!!! So just be careful...
    Cheers
  7. zebelkhan
    zebelkhan Member in good standing
    165
    38
    Morgan Hill, CA
    How did you secure the outlet in place? Just drilled the one inch hole and pushed it in?
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    The plug is so close to the battery that you could easily use 10 or 12 AWG and 20,25, or 30 amp fuse.
  9. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    cool idea.. I may do this in the future..
  10. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    The outlet is a push in, with a taper and small tabs that secure it in.
    When drilling be careful to hold the plastic steady, so the drill does not wobble the hole bigger than the 1" opening. The back side of the grey plastic has plastic ribs that I removed with a utility knife so the drill would not wobble.
    Yes, you could add the bigger gauge wire since it is right next to the battery.
    If I decided to use this for a 12v battery trickle charger I would definitely go to a bigger gauge wire that matched the charger and match the new fuse rating.
    I used it a few times and it sure beats running in and out of the house for keys to use the air compressor stored in the hatch.
    Thanks.
    Steeltrojan, zebelkhan and szgabor like this.
  11. sadie72
    sadie72 Junior Member
    45
    Chicago
    Thank you soo much for this write up. I have been wanting to to this for a long time.
    A 1 inch step bit might be a safer option.
  12. Steeltrojan
    Steeltrojan Junior Member
    New Zealand
    Three Touring
    Thanks I was wondering where I could put my plug in the rear compartment hope it fits ok. I like the power switch for safety.
