Gen III and PIP Interior Dimension Differences ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pooka, Mar 1, 2014.
  1. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    Hi all,
    I have a Gen III and thinking about PIP. I want to make sure that I can carry the same lumber lengths / ht. etc. that I can in the Gen III.
    Do the seats have the same range of motion?
    If you fold the seats down, same volume?
    Same space in cubbies under the trunk etc.?
    Do the batteries reduce any of the interior dimensions?
    The split rear view bar - same projections (for pipe lengths) ?
    if any different : whats the longest 4" pvc pipe can you fit in a PIP? (from front passenger leg space to hatch.)
    I am in KS (no PIPs) so I will be buying out of state, dont know anyone locally that I can ask. TIA!
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    The rear seats do fold down so you can use as cargo area. I transported a 55 inch flat screen TV. ( it just barely made it) with the rear seats folded down. There is no trunk because the lithium ion battery takes up that space. (no room for spare tire either) The tonneau split bar looks the same as my 2010 prius that I no longer own. hope this info. helps.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
  4. El Dobro
    El Dobro A Member
    7,093
    3,271
    The only real difference is that the spare I keep in the car can get in the way, sometimes.
  5. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    there are absolutely no interior room difference except the spare tire. all packages or equipment have the same amount form the non pip, i drove the regular Prius for 200,000 miles and now the pip for 22,000 miles and haven't noticed any space difference. you should even know you're in a pip from the interior except the badge on the dash and no spare tire.
  6. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    There's no rear storage tray, but there is a shallow storage bin under a flip-up panel at the very rear. It has a groove to store the cargo area cover roller, though if you keep that clear there's not much depth below it for other things. I use the bin for jumper cables, toolkit, first-aid kit, emergency LED flare, and a 20-foot #14 extension cord for when the charging cable isn't quite long enough. I can squeeze the charging cable in there if I try, but usually don't.
  7. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    That rear storage bin under the flip up panel exactly takes a doughnut spare wheel vertically. It is even profiled correctly to the circumference of the tyre.
  8. bisco
    52,371
    the hatch carpet is just a tad different.
    Priusmpg likes this.
  9. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Really?
    I never considered that!
    I have a proper doughnut spare- I'll have a go at it tomorrow.
  10. bisco
    52,371
    only in the uk, unfortunately.:(
  11. markabele
    5,084
    1,782
    Nebraska
    I run a delivery business out of mine and haul some pretty big boxes sometimes. Also live in the region, so let me know if you have any questions about hauling room and/or the buying process out of state.
  12. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Is that true Bisco?
    Isn't it odd just how many trivial differences there are between the US and EU PiPs.
    Perhaps Toyota need a few short lessons in cost engineering and the benefits of standardisation.
    I wonder what the reasons are for these decisions?
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    IanIanIanIan, do you have a pic with donut tire in it?
  14. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Not really but just for you:
  15. bisco
    52,371
    i don't know if it's the cubby or the wheel, but my compact spare only goes down to the edge of the hub, leaving 75% of it above water, kind of like the titanic.:(
    cwerdna likes this.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It looks the same as US PiP. Ours should get half in there as well.
    Is it the spare from regular gen3?
  17. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    I've carried up to six (6) 2x6 8 footers and closed the hatch in my PiP. I used reusable shopping bags to shield the center arm rest and side of passenger front seat.
    iPad ? HD
  18. Mendel Leisk
    41,882
    For a heady moment there I thought that meant the temporary spare could disappear below the hatch floor. ;)
  19. ny_rob
    1,968
    813
    L.I.- NY
    Went out and tried to fit my doughnut spare wheel vertically in the rear storage compartment- well it fit all the way to the bottom which left about 40% of the tire above the rear deck level.
    So, no-go for us USA PIP owners.
    retired4999 likes this.
  20. Gruvin2
    Gruvin2 Junior Member
    45
    16
    Baltimore, MD
    When I went from Gen3 to my PiP I'd swear the rear trunk space is about 2 inches higher. No proof though.
