Gen.III dead HV batteries
Discussion in 'Gen 3 Prius Main Forum' started by That_Prius_Car, Mar 21, 2010.
  1. 100,000mi
    2 vote(s)
    4.4%
  2. 150,000mi
    10 vote(s)
    22.2%
  3. 200,000mi
    13 vote(s)
    28.9%
  4. 250,000mi
    6 vote(s)
    13.3%
  5. 300,000mi
    3 vote(s)
    6.7%
  6. 300,000mi+
    11 vote(s)
    24.4%
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    This is a poll to see how long you think the HV battery in the Gen III will last.
  2. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Of course I won't be driving it 200,000 miles, I expect to replace it with a Nissan Leaf ASAP
    FYI, not many Gen 2 HV Batteries have failed yet, and it has been out since 2004 (I had one), some of the Gen 1 HV batteries have started to fail, but those are from 1999 to 2003 model years, so that is at least 7 to 11 years age wise.
  3. linuxpenguin
    linuxpenguin Active Member
    352
    182
    For real? You do know its the exact same battery as the Gen2, yeah? =)
    Andrew
  4. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    I think that it would also be necessary to take account of the parameter “time”
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Sadly, I think most of them will last right up to the time the Prius is totaled.
    (I am not voting, as I don't own a Gen III, but I want to, as the batteries did not change)
  6. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    They're warranteed for 150,000 miles in California, so I expect 151,000 miles out of mine. What I wonder, though, is how will mileage be affected by the battery's decay over time? Will the car get lower mileage at 50,000 and 100,000 miles?
  7. Tom183
    Tom183 New Member
    652
    65
    Maine
    Where's the option for "I have no idea"?
    Given the warranty duration (150k), and the typical distribution of a bell curve, I would bet that the MTBF must be high enough that 150k is still on the thin part of the curve - it would get very expensive for Toyota if 40% (or even 10%) of the batteries failed before the warranty expired.
    We don't know the shape of the curve, however - it may be more of a spike in which case they would likely park it right at 151k.
  8. bwilson4web
    16,010
    Compared to the NHW11 modules, the NHW20/ZVW30 modules are tanks:
    Here I'm helping to replace a 2001 traction battery that went 250,000 miles:
    Add to that I've studied traction battery failure and recovery modes:
    This includes what sort of abuse shortens their life:
    So as an individual, I fully expect the car to be lost in an accident before the HV traction battery dies. As for those who follow PriusChat and 'get a clue,' they can drive to extend HV life since I share what I've learned here and other forums. So I see +300k miles being more than possible ... it is what I would expect to see. Personally, I won't worry about traction battery life until after 625k miles (1,000,000 km.)
    Now there are risk factors, especially for NHW11 drivers:
    • hills - descending hills with heavy regen will 'heat pump' the batteries. Mitigation, use "B" as much as possible.
    • heat - heat is the enemy so park in shade during summer if possible.
    • high-speed, stop and go - less bad than hills, it can 'heat pump' the batteries.
    So far, we don't have enough information about the NHW20/ZVW30 modules to draw any conclusions . . . they aren't failing often enough to see patterns. Even the NHW11 traction battery failures are thin.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    No, shoot for 149,999 miles / 9 years, 364 days out of yours!
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Are you sure? I heard it was not the same battery.
  11. Tideland Prius
    16,445
    It's the same 201.6V NiMH battery IIRC.
    I expect > 300,000 miles. Most taxis here have > 500,000kms.
  12. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I confess I am dubious about interpolating taxis to normal drivers, as the computer never quits 'protecting' a taxi battery.
    A big city taxi is going to be in Ready mode almost 24/7, so the cab company gets the most profit possible, but I sleep 8 hours a day and work 8 hours a day, so my battery is not pampered as much as a taxi battery, as my car is off.
    Will this make a difference? I do not know, and at 30,000 miles a year, it may take me 12 years to find out.
  13. lolder
    lolder New Member
    Reduced battery capacity due to age does not seem to affect mpg. See: http://avt.inel.gov/pdf/hev/end_of_life_test_1.pdf. These cars had 160,000 miles and HVB capacities as low as 40 % of new. Reduced capacity might affect heavy acceleration which wasn't tested.
  14. Azimuth
    Azimuth Member
    136
    32
    Austin
    So us in Texas are at higer risk I guess.. There's no escaping 100+ degree summers here.
  15. Tom183
    Tom183 New Member
    652
    65
    Maine
    Aside from those statements conflicting with themselves ;) , can you elaborate a bit more on the risks? Pretty much anything that would create significant heat over an extended duration?
  16. bwilson4web
    16,010
    Charging NiMH batteries is exothermic, it releases heat along with the ohmic heating. Discharging batteries had ohmic heating that reduces the endothermic effect (aka., discharging does not cool the batteries.) So what happens is descending a hill forces a charge on the battery and it warms up. When climbing the next hill, there is insufficient time to dissipate the heat. So the next descent 'pumps' the battery temperature higher.
    Inside the battery, a very small amount of gas is generated, losses that are inescapable. Normally this small mix of hydrogen and oxygen simply recombines over time and is not a big deal. But the problem is heating the battery increases the internal pressure. This leads to the gas and a little bit of KOH seeping out the terminals. Over time, the losses add up, the electrolyte become un-electrolyte and a cell fails ... which fails a module.
    For more technical details: Prius Battery Photos
    The cooler you can keep the batter in spring, summer and fall, the longer it will last. During the winter, the goal is to try and keep it above freezing for optimum performance.
    DAVIDKUEK likes this.
