Gen III non-JBL Dash Speaker Upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by xs650, Jun 21, 2011.
  1. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The attached .pdf is what I did and learned upgrading my non-JBL Gen III dashboard speakers to Pioneer TS-A878 speakers.
    They made a significant improvement to my system which already had the door speakers upgraded.
  2. warpedhifi
    warpedhifi Junior Member
    27
    Denton, Tx
    Very nice job, thanks for the pictures, should help out when I get around to doing mine!
  3. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Can't open the attachment.
  4. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Adobe Reader opens it, as well as PDF Converter Pro, Irfanview and LibreOffice. I haven't tried anything else.
    What application are you trying to use and can you normally open .pdf files?
    It should be readable by anything that will read Acrobat 5 or newer.
  5. kmkremer
    kmkremer Member
    227
    30
    San Diego
    The newest Adobe Reader. Weird.
  6. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I was using AR 9.4.5 and just installed AR X (10.1.0) which also works for me.
    I'm running Windows 7
    It also works on my Wife's iMac in Safari
    Sorry I don't have any information that will actually help you. :eek:
    Edit: Also works on my Nook Color e-reader running Barnes and Nobles crippled version of Android 2.2 with Quick Office.
  7. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    If you can't read the file, I'd suggest you have something seriously wrong with your PC. Adobe has many updates to address security issues - and you are likely dealing with one of those (or a virus) - good luck....
    BTW - I just installed another Adobe update today (security related)...
  8. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Got it to open. Awesome job!
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Thanks and :cool: on getting it open. What was the problem?
  10. arnettjs
    arnettjs My gas guzzler pulls my boat!
    25
    Central Texas
    Very detailed document, thank you.
  11. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I have no idea - it just worked the next time I tried it. No doubt it was operator error.
  12. ravencr
    ravencr Member
    117
    NC
    So, if I'm searching a direct replacement speaker for the dash, I need to look for a 3.5" model? Is that correct?
    Chris
  13. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    The dash position will hold up to a 3" replacement before cutting is required.
  14. ravencr
    ravencr Member
    117
    NC
    Interesting...I can't even find a 3" replacement speaker on Crutchfield...they start at 3.5". When you say cutting, what needs to be cut?
    Chris
  15. frodoz737
    4,297
    2,348
    33
  16. ravencr
    ravencr Member
    117
    NC
    k, will do...thanks,
    Chris
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
  18. ravencr
    ravencr Member
    117
    NC
    Hey guys,
    I just purchased the above speakers for my 2010 Prius Non-JBL, and I discovered that the front door speakers look like this:
    And the rears look like this:
    Did I order the wrong speakers for the front? It looks more like a 6x9" speaker than a 6.5" round?
    Chris
  19. energyideas
    energyideas Junior Member
    24
    Colorado
    Wanted to add some value to the chat. I took the advise in this thread, but used the Polk DXi350 3.5" speakers. These are currently on sale at Crutchfields Mostly because they don't need too many watts to start. They fit into the dash sockets. I think I need to put some foam around the speaker on the left to direct the sound out better, the grill blocks too much. I dremmel tooled both sides, left and right. Used the supplied capacitor (those don't have polarity do they?). Sure wish I could adjust between the dash and the front door volumes. They are set at the same level because they are run in parallel. Any specific questions, I am at energyideas gmail.
    Thanks for the forum; hope this helps someone.
    Tracksyde likes this.
  20. lopgok
    lopgok Member
    177
    30
    unknown
    I added a 200 microfarad nonpolarized capacitor in parallel with the factors capacitor, and a 2 ohm resistor in series. I also added a 2 ohm resistor in series with my front door speaker.
    This way, the dash speakers get a go much lower, and the 2 ohm resistors keep the minimum impedance to the amp at 3 ohms.
    I started with the pioneer speakers and then switched to the polk dxi350 speakers. Though the polks claim to be 3db more efficient,
    I didn't notice much of a difference...
