GEN III Prius having boiling & beeping sound from front engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kazenone, Nov 12, 2013.
  1. kazenone
    kazenone New Member
    Dear all Prius's owner ..
    I bought Prius car on Jan 2011. This year May 2013 I have been experienced this boiling sound for my Prius car. I been sent there for diagnose but toyota seems want to get rid of this
    This is answer they given for my issue..
    1. Boiling sound and beeping sound when driving.
    The sound which the Complainant had experienced originates from the vehicle’s cooling system. The said sound is produced by the cooling system’s coolant which circulates through the engine. This is a characteristic of the vehicle and there are no abnormalities with the vehicle’s engine.
    I have tried my friend Prius car and their service center demo car as well. I didn't heard this abnormal sound produce.
    Is there anything wrong with my car?
    Hope yours can help me on this. Much appreciated.
    Thanks,
    Kaze
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    send it up the line .. call toyota care and open a case.
    ou812 and kazenone like this.
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I'm not sure what a boiling sound is. Have you had another Gen III Prius owner drive the car and comment on the sound(s)?
    kazenone likes this.
  4. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    My 2001 Ford F-150 did this everytime the engine was turned off. I figured it was a high pressure bypass valve to allow the pressure to bleed off rather than have a cooling system under pressure. I cant say if my 2012 Prius does it as I am so used to sounds and noises, I dont pay attention to it.
  5. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
  6. bisco
    49,434
    i've never noticed a boiling sound whilst driving, except my blood pressure. try another dealer?
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    By a boiling sound, could this be the same sound as air bubbles in the coolant? Have you had the engine coolant replaced any time recently? If so someone may not have bled the air properly.
  8. kazenone
    kazenone New Member
    Yes, Toyota already open case for me and investigate about this sound and they finalize this boiling sound is characteristic of vehicle. I actually requesting them to have another GEN III to make comparison, until now they didn't reply my email yet ?
  9. kazenone
    kazenone New Member
    Yes, my friend has one. And i monitor his car for few months,his one seems like OK, don't have this kind of boiling sound.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You mean the dealership "finalized" the findings?... I mean contacting Toyota Corporate and have them open a case because the dealership (as it seems to me) is giving you a line of BS. This sound from what I can tell (not actually have heard it) is not characteristic.
    As also mentioned, try another dealership if you are able.
  11. kazenone
    kazenone New Member
    Actually,4 times i went Toyota service center, they keeps said nothing wrong with this sound and they said their test drive demo car having this sound as well, but then they unable to prove me more details on this, even though i request for video capturing for the boiling of the said car.
  12. bisco
    49,434
    you need to find a friend or someone else who can hear the noise and help point it out to the service manager on a test drive.
  13. Former Member 68813
    3,524
    981
    US
    We need a recording of the boiling.
    Never mind, I found it:
  14. bisco
    49,434
    that's it!
  15. kazenone
    kazenone New Member
    I will upload it tonight thanks
  16. Martholland
    Martholland Junior Member
    Netherlands
    I know that sound. After a drive and the car is parked I hear also that sound. No problem. It has to do with the cooling down. I noticed it this summer and since then I drive more than 10.000 km.
