Gen III to Gen III HV Battery swap.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Colm01, Feb 17, 2015.
  1. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    1. Hello all, I'm trading my 2010 Prius II for a 2010 Prius V w/ATP in mint condition. The II has 39K on it and the V has 97K on it. Since it's a Toyota, I'm not too concerned about the higher mileage except for the HV Battery. My question is, can I just swap the HV batteries? Are they Plug and Play? Or are they serialized and need to be programmed to the Prius it's going into? I'm not too concerned about the warranties. Thanks!
    49,431
    how can you swap batteries if you're trading in?
  3. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Good question. I'm paying $12,700 cash for the 2010 V, which is almost the same as what CarMax and Webuyanycar has offered for the 2010 II. A trade in a sense I guess, but not trading in. I should have been more clear.
    49,431
    gotcha, anyway, it's just plug and play, no differences in the same generation.
    GG707 likes this.
  5. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Thanks for your help bisco.(y)
  6. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    I'd be interested to see some photos and a write-up describing the experience.
  7. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Sure Dylan. I plan on doing it probably next weekend. I hope the battery can be moved by two people since I don't have access to a hoist.
    Dylan Doxey likes this.
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Was the II orig purchased in DE? If orig purchased in NJ or MD it would have 150k miles warranty over there.
  9. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    Yeah, the II was orig purchased in DE. The V was orig Purchased in VA,
  10. bisco
    49,431
    you won't have any problem, everyone pulls them by hand, even the battery thieves.:p
  11. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    sounds like 2 non-CARB states so OK...DE is actually new member of CARB but DE does not get the 150k extended full CARB warranty
  12. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    I tried to start swapping the batteries last weekend. The 20 degree temps were causing the plastic clips to break that held the interior trim down so I aborted the swap for now.
  13. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    I went ahead and swapped the battery assemblies today. It took about 2 hours and I did take pictures to post later. My issue is, that all the dash lights are on and the "Check Hybrid System" warning is on in both cars. Both cars will not go into gear and the engine will not start. Both batteries are displayed at 6 bars. I've tried disconnecting both the Aux battery and the service plug but to no avail. Any ideas?
  14. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Are you completing the service plug installation fully by sliding the clip to the right?..
    wjtracy and Colm01 like this.
  15. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
    That was it. Thanks m.wynn!(y)
    m.wynn likes this.
