Gen III vs. Gen II - same 3,100 Road Trip
Discussion in 'Gen 3 Prius Main Forum' started by marcoinpb, Jun 7, 2010.
  1. marcoinpb
    marcoinpb Junior Member
    62
    24
    2018 Prius Prime
    Gen III (IV) Road trip from FL to DC to CO (3,100 miles). Heavy load, speed generally 75-80mph. 50 mpg. The Prius had 1,100 miles on it before trip. Front tire pressure: 51, rear tire pressure: 48.
    Last year, same trip with 2007 Gen II about 44 mpg. There was nothing wrong with my Gen II Prius (86K miles), I loved it and had no intention to replace it but the dealer made me “A Deal I Could Not Refuse.†With great surprise (I had not been in a Gen III before the actual delivery of the 2010) I am amazed at the substantial improvement in the Prius (perhaps dash/instruments exception). The same load last year in the Gen II set the rear of the car within 1 inch of touching the rear wheels, the Gen III does not appear to sit down at all.
    My Mercedes SL55 is comparatively a crude car when comparing any of the electronics to the Prius – although the top goes down and it does sound good! Obviously, if I did not drive the Prius on any trip longer than about 5 miles, I could not own the SL55 – it MAY attain 11 mpg on the highway, but it does have 519 HP!
    Any questions?
  2. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Any questions? Yes, what are you trying to say here, notwithstanding the comments about the SL55?
    Not too sure what you meant by "The same load last year in the Gen II set the rear of the car within 1 inch of touching the rear wheels, the Gen III does not appear to sit down at all."
    Are you indicating that the Gen III was better or worse on the mileage? All I see here is a description of the trip that you took in both the Gen 2 and 3, and that you got about 6 mpg better this year than last. What questions did you want/expect us to have?
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    wow, tire pressures at 51F/48R? Goodness, I thought the max cold psi was 44 for the stock Yokahomas tires.
  4. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I keep mine at 49F/47R all the time. It rides great and gets above 55MPG per tank
  5. marcoinpb
    62
    24
    2018 Prius Prime
    The OEM tires on my Gen II were kept at 51/49 and were replaced at 51,000 miles. Argueably, they had another 5-7K left on them. My experience on other cars I have owned has never resulted in long lasting tires.
  6. silentak1
    893
    28
    LA
    What are your OEM tires? Yokahomas S33D, Goodyear Assurance or Bridgestone EP? If they were the Yokahomas, I might increase mine from 40/38 since your long trip didn't result in some type of tire blow out.
  7. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Odd post.
    Nice to hear about the II vs III info, although light on info.
    So what - about your Mercedes? Just want to brag to a Forum that could care less?
    Notice I did not mention my Jaguar.
  8. marcoinpb
    62
    24
    2018 Prius Prime
    The tires on the Gen III are Yokahomas AVIDS33. I do not recall what the originial tires on the Gen II were.
  9. silentak1
    893
    28
    LA
    Thanks, G2 were Goodyear Integrities. Some G3 came with Birdgestone EP20 and Goodyear Assurance something tires, some only. Good post.
  10. bisco
    49,446
    thanks m, interesting test results. i suppose there must have been some variables but it sounds like the III is a definate improvement in hwy mpg and suspension. what about things like comfort, room, noise, power, ride quality, etc.?
  11. bwilson4web
    15,518
    The irony is a Prius makes owning a pony car practical. The right tool for the right job.
