Gen1 front wheel bearing+hub+nut+snapring $27 closeout RockAuto
Discussion in 'Generation 1 Prius Discussion' started by pmc, May 19, 2023.
  1. pmc
    pmc Junior Member
    16
    Chicagoland
    2002 Prius
  2. dabard051
    dabard051 Tinkerer-in-Charge
    247
    92
    Rochester, NY USA
    2002 Prius
    Just a heads up... the in-place clip ring (if it is OEM) has been inplace for over 20 years, and may require significant skill to remove.
    Particularly if the vehicle has been driven in salt-prone regions....
    The bearing will need significant force to remove, so consider a bearing removal kit. Or a machinist....
