Gen2 bleeding brakes rant.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by _echo, Mar 19, 2012.
  1. _echo
    _echo Junior Member
    83
    Orange County
    Hello All, Decided to bleed brakes this weekend since I'm now just a bit over 105kmi. Nothing was wrong with them, just decided that it was time. During the process, I ended up thinking that I screwed something up. The brake 'blob' is a $2400 actuator assembly, a sort of master cylinder, hydraulic, electromechanical monstrosity. If it's already screwed up and throwing codes, it dosen't hurt to keep trying, right? In the end, I managed to get it functional again. Just had to keep trying logical solutions. This car is a great vehicle, no problems yet. I don't expect anything that won't be caused by the "loose nut behind the wheel." AKA, my futzing with it. So, if I haven't bored everyone, the work log below should probably do the job. This rant is a brain dump, partly to myself so that I don't screw it up again. It might be useful to those of you that are going to work on the brakes. The Autoenginuity does support brake bleeding on the gen2, however it still has bugs in the software. When bleeding the rears, you're supposed to put the relays IN! An annoying thing happened while doing one of the rears. If you bleed them you don't have to pump like on 'normal' brake systems. You just push the pedal down, and open the valve. The brake pump takes care of everything. What I learned today is that you should NOT open the thing up too much. If you go too fast, something makes a clunk, folllowed by no pressure to that piston. That, along with a sinking feeling that this is going to be a long day. :( If you open it again, you'll notice that SOME fluid is coming out, but not much. It's definitely not due to air in the system. What was really scary was that trying to rotate the drum with the pedal depressed caused free rotation on that wheel. Also, the piston pressure sensor remained at a constant value (low voltage.) The other three wheels read proper values. Removal of the relays and pumping the brake pedal rapidly should depressurize the accumulator. I did this many times, well into the beep of death. Interestingly, I think that also unstuck the solenoid. I didn't check this, but decided to grab my other PC. My garage laptop had a much later version on it (I think it's one of the 9x series?) Out of desperation, I ended up going back to version 7.4.3 since I had it on my other machine. I used that last time I did bleeding. After reinstalling the relays, and letting the system pressurize, the piston had full pressure on it once again. I'm not sure if it was the change to an older version, or whether it was the 'no power' depressurization. Repeating this experiment to determine whether something broke in the software, or if it was some other factor is something I don't want to do. Fortunately, brakes are now smooth. For some reason, bleeding the brakes helps alleviate the 'grabbiness' that people attribute to the prius brakes. In fact the reason I do this, along with lubricating, and cleaning up the brake parts (slides, rotors/drums, etc.) is because it seems to make the car much smoother, about as smooth as a non-hybrid. It's important to check your work after you complete the brake stuff. Aside from stepping on the brakes and trying to rotate the wheels, setting up the scantool to watch the sensors is also quite informative. Once buttoned up, a test drive is of course mandatory as well. FYI: I'm sure that the motorcycle people already know this, but for the first time, I have seen the interaction between front and rear brake response in real life. In the order of increasing brake pressure, it looks something like this. The car first preloads all cylinders, and then applies the rear, followed by the fronts. Does this mean that the shoes wear out first when you try to capture maximum regen? This is the second time I've bled the brakes on this car. The first time, the fluid came out pretty much clear on all 4 pistons, this was at the ~50k mark. This time, I noticed that the drivers side front piston came out a bit brown for the first two pumps. All of the other pistons were clean. If anyone has a 'dead' brake actuator, it might be good to do some analysis on it (AKA internal photos) I would certainly like to take a look at the guts of one, there's some really interesting engineering in it. Repurposing it for robotics would be even more fun. A hydraulics package about the size of a 6 pack could be used for all sorts of applications!
  2. cnschult
    cnschult Active Member
    772
    96
    Michigan
    did you check this forum before bleeding your brakes?
    i'm pretty sure its one of those things that has to be done at the dealership because they have to hook the car up to toyota techstream software to bleed the brakes properly.
    I find its fairly common for the front brakes of a car to wear before the rears, especially if the rears are drums with rotors up front. I'm on the advance auto parts website ordering brakes for my corolla with 70K miles is barking at me, while my prius with 50K miles has most of its pads remaining, most prius owners report 150K+ miles on a set of pads, with the rotors rusting out under us due to underuse.
    the only brake maintenance your prius needs is a dealership brake bleed job every 100K and you should lube the front caliper slides & clean/adjust the rear drums every 50K miles. then just replace pads/shoes/rotors as needed.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Paragraphs! Please use paragraphs.
    I won't even attempt to read a monolithic post like that unless I'm really desperate.
    Tom
  4. cnschult
    772
    96
    Michigan
    LOL i skimmed it quickly before making my earlier response so my response may not be accurate as I may not have had all the information.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Exactly. He lost me at "blob"
  6. pliers
    pliers New Member
    Thanks so much for the help. I had the same exact situation. I bled the front OK, but no pressure after bleeding the back. I had no pressure at the back and I knew it wasn't due to air, and of course, I had no rear brakes. I incorrectly bled the brakes without the scan tool or doing the other steps such as removing the fuses which I know know about.
    I believe what fixed it for you was when you changed operating systems, you reset the fault codes.
    All I did was to reset my fault codes and the brake system started functioning normally again. Follow the procedure here:
    CLEAR DTC (When not Using Intelligent Tester) | PriusChat
    I learned my lesson and won't just jump into maintenance again without reading first.
    hydrowindandsolar likes this.
  7. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
    He lost me at "Decided to bleed this weekend." There's not much to say after that other than: "Make sure to tow it to the dealer on Monday."
