Gen3 Air Fuel Ratio Sensor Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saak, Aug 2, 2016.
  1. saak
    saak Junior Member
    42
    Alberta, Canada
    I have a 2010 Prius with 160k km, need to install new Air Fuel Ratio (AF) sensor, got the original Denso sensor, can somebody please guide me how to access and replace AF sensor ? do I need to remove any thing from under the car to access it ? is it on driver side or passenger ? a full procedure or video would be very helpful. Thanks.
  2. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Do you mean the mass air flow sensor, or the oxygen sensor, which is the part most involved in reporting current air/fuel ratio?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    is this for the upstream or downstream sensor of the cat? Did you get a code that required you to replace the sensor? Or were there some symptoms leading to replacement?
    To answer your question the sensors are along the exhaust manifold. You'll have to remove the engine splash guard underneath to access the upstream sensor.
    #3 Raytheeagle, Aug 2, 2016
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    The Air/fuel sensor should be by the exhaust manifold. Its right before the cat. You will have to remove the under body plastic panel to get access to it.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Make sure you do this when the engine is cold...................just sayin....................
    Rebound likes this.
  6. NutzAboutBolts
    1,601
    1,691
    Bay Area
    lol for sure
  7. saak
    saak Junior Member
    42
    Alberta, Canada
    yes I have obd code P2196. I need to replace upstream oxygen sensor (air fuel ratio sensor). Is it on driver side or passenger, anyone has any document or video of replacement procedure.
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    They are off the internal combustion engine, so on the passenger side.
  9. saak
    saak Junior Member
    42
    Alberta, Canada
    Mendel Leisk and Raytheeagle like this.
  10. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
  11. Mendel Leisk
    40,584
    In case anyone's scratching their head about the "No 2 Cylinder Head Cover", it's this:
    BTW, when I click on links in your attachment, they WORK. For example wiper and cowl removal. Is the TechInfo paywall down. I kinda hate to ask this. Not complaining.
