Gen3 driver's Power window for other windows stopped working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Norwich2, Apr 19, 2019.
  1. Norwich2
    Norwich2 Junior Member
    Virginia
    Today I went to power down all the windows in the car as I was driver (alone) and I detected a lag on the non-drivers windows. I raised them and tried again and none moved (except the drivers one). When I rached over and used the control on each door though, it worked fine. What do I need to do to fix the driver's side control for the other three windows? They are effectively dead. I do see a little spot like an LED on each...so maybe at night I can go back out and see if they light at least.
    Marc
    49,511
    hard to say, you probably need to pull the switch out and check the connections. is the 12v okay?
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Press the Window Lock Switch and reply back in the morning.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Yeah, this is a very stupid setup. Block the kids in the back to stop playing with the windows, only to find out you actually blocked yourself too
    I can't understand toyota's logic
