Gen3 Inverter Coolant Temp?
Discussion in 'Gen 3 Prius Technical Discussion' started by JimN, Dec 28, 2011.
  1. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The XGauges for Inverter MG1 Temp (I1C), Inverter MG2 Temp (I2C) & MG1 Temp (BTA) read the same value. On battery power only the value is usually 655. When using the ICE the values will fluctuate down to single digits: 1.xx, 5.xx, 6.xx... and change in quantum steps.
    Which XGauge should I use to monitor inverter coolant temp or should I be looking at something else? What is the normal operating temp? Are my strange readings an indication that I need a firmware upgrade?
    OAT has been in the 30's--40's F with max coolant temp in the low 180's F and the grill fully blocked.
    My ScanGauge II is at least 3 years old. Thanks for the advice.
    Jim.
  2. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Inverter coolant temp generally runs 20 degrees F higher than outside temp.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I think I would first check the configuration parameters you are using against the Adrian Black spreadsheet to make sure you are using the correct parameters for the Gen III. I have these same XGauges configured and I am not having the problems that you indicate.
    If these parameters are correct, then I would agree that your ScanGauge needs an firmware upgrade.
  4. ngc4565
    ngc4565 Member
    156
    17
    Pennsylvania
    If you cannot manipulate this temperature then there is no point in monitoring or worrying about it, right?
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    If you block the grill it is important to monitor both the engine and inverter coolant temperatures to make sure you do not cause overheating.
  6. JimN
    7,028
    1,116
    South Jersey
    jd, what is your firmware's version? My version is 3.15 so the unit is being returned for an upgrade.
    I downloaded the Black spreadsheet & it appears to be the abridged one posted on the Scangauge site.
    Thanks to all for the help.
  7. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Mine is rev 4.05. So, your issue could very well be with the rev level of your ScanGauge.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    My Scan Gauge has ver 3.15 and the inverter coolant temp x gauge works fine.
  9. Den49
    Den49 Member
    498
    268
    Maryland
    I purchased a Scangauge II last month and am using the "ICF-Inverter Coolant Temp" XGauge to monitor inverter coolant temperature. I wanted to check the inverter coolant temperature after closing off two holes in the engine undercover below the inverter. On a 45 degree day, the inverter temperature was 50 to 55 degrees.
    More eye opening was the range in engine coolant temperature (FWT). When the engine was running the maximum temperature was 190 to 198. When the engine was not running it was as low as 170. 170 to 198 is a wide range and a fairly cool operating temperature for an ICF which may explain why Toyota recommends 0W-20 engine oil.
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I also see the Inverter Coolant temp in the 10-20 degree range above ambient, depending on ambient temp.
    As for the engine coolant, the thermostat is set for 195F so the reason for the upper range. As for the lower range, the ICE can turn off as low as 115F depending on conditions. So much wider than what you indicate above.
  11. Den49
    Den49 Member
    498
    268
    Maryland
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
  13. JimN
    7,028
    1,116
    South Jersey
    Thanks all for the guidance. My unit is off to the factory. I miss my gauges & it's only been 1 day. This is going to be a rough week.
    I run fully blocked most of the year & have seen coolant temp above 195 very few times. I'd say the best chance of it happening is in stop & go city traffic in the summer.
  14. Den49
    Den49 Member
    498
    268
    Maryland
  15. jdcollins5
    5,131
    1,338
    Wilmington, NC
  16. Den49
    Den49 Member
    498
    268
    Maryland
  17. jdcollins5
    5,131
    1,338
    Wilmington, NC
  18. JimN
    7,028
    1,116
    South Jersey
    My updated ScanGauge was delivered sans manual so I poked around enough to get it to work. I printed the manual & the XGauges from their website.
    The increased functionality is like night & day. Some of it looks like it will be fun to play with while I hope I never use other parts.
    I set up ICF tonight after dinner & was rewarded with a stable reasonable figure just sitting in the driveway withe ICE not running. I'm looking forward to seeing what happens on tomorrow's commute.
    For those with 3.x firmware I believe the upgrade is worth the price of admission. Look through the new manual on line & decide for yourself.
    Jim.
  19. JimN
    7,028
    1,116
    South Jersey
    Today's commute showed inverter coolant temp rose to OAT + 40F. I'm figuring that this is not a problem right now as it is freezing. I'm starting to unblock the grill to bring the temp down closer to OAT + 20F.
  20. Kb2lzh
    Kb2lzh Junior Member
    16
    Ca
    My Mg1 after traveling 70 miles at speeds of 65 MPH was at 204 F. I have tried to search to find out what the operating temp should be, but this site is tedious to search.
