Gen3 P0A80 with 50 mpg
Discussion in 'Gen 3 Prius Main Forum' started by Doruk, Jan 6, 2023.
  1. Doruk
    Doruk New Member
    Miami
    Hi guys! Recently i bought 2010 prius with P0A80 code on it with 190k mile. The car pops up the code in every 50 mile but when i clear it with my scanner everything works fine. I’m getting 45-50mpg. Today with 60 miles driving i got 51.2 mpg. I haven’t scan the cells yet because my OBD scanner cant read it. I got few questions;
    Q1: Is there any app for ios for scan cells for prius? If answer is no; torque is the best for android?(i might need to get android phone just because of this)
    Q2 : Could this code occur for any reason other than dead cells in the battery?
    Q3: If i scan the cells and change the dead ones, can this code go away by itself?
    Is there anybody who experienced same problem with me? What is your suggestions?
    Thanks in advance
    52,433
    dr. prius app
    2) no
    there are tons of battery rebuilding threads here. you can replace bad modules with good ones, but be prepared to keep doing that as more fail.
    you can increase the longevity between failures by balancing the modules after the swap.
    it's all laid out in other threads, but not all in one place unfortunately
  3. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    You can also use hybrid assist to scan cells, use torque to clear fault codes... Could also be as simple as corroded bus bars... Clean and clear codes.. Worth a go.
  4. Doruk
    Doruk New Member
    Miami
    These are the last 3 pics i made with the prius app. Can you guys tell me which cells should i change for the clear P0A80 code and run it like a champ again!
  5. Doruk
    Doruk New Member
    Miami
    Additional ss from different days
  6. bisco
    52,433
    idk, but there are lots of battery rebuilding threads here that would have that info
  7. Doruk
    Doruk New Member
    Miami
    thank you dor replies. Yeah i know those threads and know how to change battery cells but i dont know how to read prius app in a correct way. I dont want to do something wrong
  8. bisco
    52,433
    gotcha. well, if no one can help, there are lots of doc prius threads as well. all the best!
