Gen3 Prius Cargo Space (revisited again)
Discussion in 'Gen 3 Prius Main Forum' started by wjtracy, Oct 9, 2013.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    OK boring topic, but I see another on-line automotive community is struggling with the cargo space quotes (for example 21.46 cu ft for Gen3), and I think I recognize some PriusChat members in that discussion:
    CARGO/LUGGAGE VOLUME: When standardized isn't always standardized
    Gen2 Prius was quoted at 16.1-cu ft cargo space, which I can approximate from my vehicle. But 21.45 cu ft cargo space for Gen3 seems hard to explain, given Toyota says Gen3 only has +3.0-cu ft more total interior space over Gen2. There must also be a change of cargo space measurement technqiue at play here.
    Everything I know on this topic is taken from the Toyota discussion of Gen3 specs on the YouTube video posted below:
    Gen2 Total Cargo space = 16.1 cu ft (Toyota brochure)
    Gen3 Total Cargo space = 21.45 cu ft (seats up) (from video below 4:15 minute mark)
    Gen3 Total Cargo space = 39.60 cu ft (seats down)
    Gen3 Under Tonneau Cover = 10.24 cu ft (and this is +0.5 ft3 more than Gen2)
    Gen3 Under Floor = 1.98 cu ft (and this is +0.5 ft3 more than Gen2)
    OK that's all I have official from Toyota.
    Unaccounted for Gen2 vol = 4.8-ft3 (approx space above Tonneau + cubby hole)
    Unaccounted for Gen3 vol = 9.2-ft3 where is all this volume? some is above Tonneau cover
    Gen3 specs video from Toyota...also qualitatively in the video he says Gen3 just has a little more cargo space.
  2. 3PriusMike
    3,101
    2,419
    Silicon Valley
    I think the new method allows folding down the rear seats.
    Mike
    wjtracy likes this.
  3. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Sounds like you might be on the right track Mike...if true, would it be too harsh to say the new method is a step in the wrong direction?
  4. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    The thought in that thread was that the Volt was only being measured to the top of the rear seats, and that the Prius was measuring the entire area. Where is your number of 10.24 cu ft for the Prius under the tonneau cover from? If the Volt's numbers are in fact correct - ie. 10.6 cu ft to the top of the seats, I can't see the Prius having effectively the same amount.
    It would be extremely odd if Toyota were measuring cargo area with the seats down. There are always two different numbers.
    What I took from that thread is that with the seats up, the Volt probably has a bit more than its rated capacity, and the Prius a bit less. That doesn't change the fact that small differences on paper can translate into big differences in reality, and that having tested both cars, I can fit a lot of necessary stuff in a Prius that I couldn't in the Volt.
  5. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ZH, I got the number from Toyota youtube video 4:15 minute mark
    I take it Mike is saying the new technique may involve folding the rear seats down and then somehow defining an invisible line separating the rear cargo area...effectively adding the volume excluded by the seat into the cargo volume.
  6. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Thanks. That same spot says 39.6 cu ft with the seats down, so that's not it. My old Volvo wagon was rated at 37 cu ft seats up. By that metric, the Prius, at a bit over half that space, seems about right.
