Gen3 wheel covers
Discussion in 'Gen 3 Prius Main Forum' started by Kimoy, Apr 12, 2010.
  1. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    Why does the gen 3 have wheel covers even if you have alloy wheels. This only on the 15 inch wheels not the 17's.
  2. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    What's the purpose of the wheel covers when you have alloys? Does removing it affect the performance of the car? Aerodynamic, wind resistance, mileage, and what not?
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The answer that I have seen on here the most is aerodynamics and gas mileage. I have also seen several posts where the covers have been removed with either no noticeable or negligible reduction in mpg.
    I just bought some of the center cap plugs to cover the holes on the alloy wheels and have removed the plastic covers. I think the car looks so much better without the plastic covers.
  4. WEB211
    WEB211 Junior Member
    Nicholasville, Kentucky
    How about some pics with the center cap plugs? Do the hubcaps just pop off? Thanks.
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I will see if I can get some pictures tonight.
    Yes, the plastic hubcaps just pop off. Reach just inside of the plastic hubcaps and pull towards you.
    The center caps just snap in the holes in the alloy wheels, also.
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    There are alot of threads discussing the center caps for the wheels with pictures, you can probably find one with the search.
    Here's one pic I have in my album but it's not a great one showing the caps in place.
  7. Superdrol
    Superdrol Member
    399
    32
    i like the plastic covers over the rims. That was if you skin a curb or something similar, you can replace the cover vs. having to drive a scratched up rim.
  8. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    Is that the alloy wheels that comes standard on the gen 3 or an option?
  9. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    And where did you get the plugs?
  10. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Those are the alloy rims which are under the 15" wheel covers on the 2010 Prius II-IV .
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    You can order them on parts.com
    There are threads on here which can be found using the search with links to parts.com showing the part number. And I think there are 2 different styles which can be ordered. In the thread are pics of each and the part number for each...
  12. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  13. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
  14. njmurvin
    njmurvin Member
    103
    Simi Valley, CA
    Here's a thought. For those of us leasing, hang onto the covers if you elect to take them off during your lease. Before turning the car in, be sure to put them back on or you might get dinged for a full set (not to mention covering up any minor curb rash).
  15. good-sort
    good-sort New Member
    US
    For those of you that are opting to remove the "Gen3 wheel covers", is anyone willing to part with these wheel covers (hub caps)? One of mine flew off and someone ran it over.:(
    Please let me know if you are willing to part with one or more of your old wheel covers. This would be for a 2010 Prius IV 15" wheels.
    Thank you very much!!
  16. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    Paradox, where do you get the plugs???
    I went to that site cheaperparts that you had posted in another forum and there is an error on the page when it loaded.
  17. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    "Danger Will Robertson ... "
    When buying the center caps, if you've not already run into this discussion elsewhere, you should know that there were two very, very similar looking center caps ... which were not interchangeable ... when we went shopping for Gen II caps. Slight difference in diameter.
    The correct one had the Toyota symbol surrounded by a smooth chrome-like surface. The wrong one has the Toyota symbol surrounded by a fine-mesh chrome-like surface. I'd wager a guess that the same ones which fit the Gen II Prius also fit the Gen III.
    When I had my Gen II, I finally joined the ranks of many who simply bought them from a dealership, as the total cost wasn't much more than they go for on eBay etc., and that way I knew I had the right ones. In fact, the service manager took them from me when I returned from parts and put them on the car for me.
  18. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    parts.com is the place where a lot of PC'ers have gotten their caps. See my post below:
