General Driving Efficiency
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, May 29, 2023.
  1. bwilson4web
    15,513
    These are general guidelines, not hard and fast rules which are vehicle specific:
    • gas ignition engines
      • Pays a 'warm up' cost of heating to operational temperature.
      • Pays a waste heat cost keeping the drivetrain cool enough.
      • Pays a partial throttle cost from reduced compression-to-expansion ratio.
      • Pays a transmission loss matching engine speed to wheel speed.
    • diesel ignition engines
    • hybrid, Toyota style
      • Avoids partial throttle cost by operating engine at peak efficiency.
      • Uses electric for partial power mode so engine runs at peak efficiency.
      • Pays a low transmission loss matching engine speed to wheel speed.
    • battery electric, Tesla style
      • Insignificant 'warm up' cost.
      • Insignificant waste heat cost keeping the drivetrain cool enough.
      • Insignificant partial power mode loss.
      • Insignificant transmission loss.
    This was brought home last night when on a single charge, I reduced my speed to achieve 5 miles/kWh and avoid a charging stop. Normally, I get about 4 miles/kWh at posted speed limits. At higher traffic speeds, this falls to 3-3.5 miles/kWh. Had I been in any other vehicle, going slower would be 'less bad' but the waste heat and transmission losses would cost.
    When driving at traffic speeds (i.e., posted speed + 10 mph,) I have to go fast DC charger to fast DC charger. Arrival at each fast DC charger is at minimum battery level so charging is as fast as possible. Charging duration is often less than the necessary biology break.
  2. hill
    8,158
    Might not the efficiency observations include "utilizing" waste heat from plug-in ICE - to both warm cab & traction pack, plus recharge traction pack - as well as range extending? Especially during sub zero temps?
    bwilson4web likes this.
  3. bwilson4web
    15,513
    If I saw evidence of waste heat usage beyond cabin comfort, yes. But the waste heat is about two orders of magnitude greater than cabin heating requirements.
    As for BEVs, the example of mine, the cabin is preheated or important in Dixie, cooled by grid power. Within the time it takes from deciding to leave and getting in the car, ~10-15 minutes, it is done. The comfort maintenance energy is much less than cold aerodynamic and tire effects. Air conditioning is fairly low. More recent Teslas use a heat pump for even less loss.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    1,840
    873
    I've contemplated putting a heat storage tank on an ICE vehicle and coming home to use it instead of a hot water heater.
    On the flip side I've thought of running a generator at home to charge an EV and using the waste heat to heat water or the house.
    (Either way I don't think my landlord would aprove).
    Everything has pros and cons. Using just a onesided approach doesn't mean that there are no cons. Take charging an EV at home for an example, which may be easy for some people but near impossible for others. I write this from a home with two ICE vehicles that are regularly driven and a 30A 120V power service for the entire house.
    #4 Isaac Zachary, May 29, 2023
  5. fuzzy1
    10,163
    Install rooftop solar generator to charge the EV, and to operate a heat pump water heater, and to operate heat pump HVAC, and handily beat all of the above.
    That would scuttle my suggestion too.
    That must be ancient. I think even the current local "tiny houses" have greater service than that.
  6. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    After using the i3 as a daily driver for over a year now, I've found it cost the same or even a bit more than when I was driving the '01 Prius. I do all my charging at home, so on paper this doesn't make sense. Part of it might be electric rates have gone up, but I think it's mostly due to the extra power used to precondition the car during the colder months, and getting all the cabin climate control from battery power. In winter there's no extra cost for heat with an ICE. When the ICE idles it waist energy, but some of that goes into the AC on hot days.
    bisco and Isaac Zachary like this.
  7. Isaac Zachary
    1,840
    873
    In countries like the USA, yes.
    But in places like every country from Mexico to Argentina and in between, that's pretty much standard. Of course some would contend that in those countries there aren't enough drivers or typical driving distances to make much of a difference if they drive ICEVs or EVs.
  8. Mendel Leisk
    38,652
    Ah cripes, you may have just coined another acronym.
    Isaac Zachary likes this.
  9. Trollbait
    11,511
    Actually been around for some time. I believed coined around the time of HEV and HHV, which happened before they were used here. Context of our discussions, mostly means it is safe to drop the V. Which lead to most not knowing there was an ICEV.;)
    I think there is a SAE Lexicon out there that gathered all these terms up, if not actually create them.
    HHV = hybrid hydraulic vehicle
  10. bisco
    49,392
    big difference in climate between indy and bama as well
  11. Isaac Zachary
    1,840
    873
    Doing some quick googling, there seems to be a little over 50 million vehicles driven in Mexico and another 50 million in Brazil. By contrast there are around 238 million drivers in the USA. I'm not sure exactly how vehicles vs drivers relate between these countries, but I'd be willing to guess that the vehicular air pollution problem from all of Central and South America is comparable to the entire USA, if not actually worse.
