Generation 4 2016 Prius 4 year Update
Discussion in 'Gen 4 Prius Main Forum' started by JImmyPriNew, Sep 26, 2020.
  1. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    I finally uploaded my 4 year review - almost 4 and a half. It is at
  2. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Nice review. 12V battery: have you added distilled water to the battery?
    kithmo likes this.
  3. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for your comment and for watching. From what I understand it is a sealed lead acid battery they doesn't need refill.
    Pulse07 and alanclarkeau like this.
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jim,
    The little caps with the cross on them can be unscrewed and you can carefully top each cell off with distilled water. "Sealed Lead Acid" or "Maintenance Free" are marketing statements on car batteries and are false statements (unless you have an AGM battery as was the case in earlier Prii that had the battery in the "Boot') so top the cells off and your battery will last longer.
    The Cold Cranking Amps are an indicator of remaining battery life, but are not really relevant for a Prius as the 12v battery is never asked to supply high current (The Traction battery starts the gasoline engine in a Prius). You were correct to ignore your dealer's attempt to empty your wallet.
    JeffD
    kithmo, Mendel Leisk and davecook89t like this.
  5. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for clearing that up. I knew something didn't feel right the way they were saying I needed to replace the battery right away but I didn't know exactly why. Thank you for watching the video.
  6. krmcg
    2,592
    2,392
    Whittier, CA
    nicely done. I wonder if you could remove the plastic protection strips and clean up that area? If you could, it would look better - and I don't know how much "protection" they are providing anyway.
    Harters and alanclarkeau like this.
  7. ShuttlePod
    ShuttlePod Junior Member
    Colorado
    2020 Prius
    Nice. I liked your videos on Prius camping as well. I had a perfect hotel Prius setup in my 2008. The 2020 still needs a few tweaks, but is coming along nicely.
    #7 ShuttlePod, Sep 26, 2020
  8. Mendel Leisk
    41,928
    I'd debate the relevance of CCA: a battery nearing end of life will display low CCA, regardless. It may not need high CCA, but it's still dying.
    I've found the best way to determine the need and do a distilled water top-up, get them uniformally back to the top line, is to disconnect and remove the battery. Set it with a light behind so you can clearly see the levels.
    Good time to clean the top of the case, the posts and cable clamps as well. Use a strip of fine sand paper on the posts, wipe them off, then bag and dispose the sand paper and cloth: it will have lead dust.
    #8 Mendel Leisk, Sep 26, 2020
    davecook89t likes this.
  9. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks and thanks for watching. That is a good idea as long as I don't scratch through the paint and start a corrosion problem.
    krmcg likes this.
  10. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for the tips and for watching. I used to do a lot on my older cars these days not so much.
  11. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks and thanks for watching. I haven't camped in a while. I think my favorite camping area has been closed for a while.
    alanclarkeau likes this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Harters, krmcg and alanclarkeau like this.
  13. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    kithmo likes this.
  14. pianewman
    264
    183
    2018 Prius
    JLmmyPriNew: Would you be willing to remove the 12V screwcaps and check electrolyte level? I'm very interested. If it's low, you should probably add some distilled water (you probably already know that!)
    krmcg likes this.
  15. Ty D
    Ty D Junior Member
    2018 Prius
  16. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for your comment and for watching. I am thinking about it.
  17. JImmyPriNew
    JImmyPriNew Member
    34
    63
    Hilo, Hawaii
    Thanks for your comment and for watching. I am on Hawaii Island, the Big Island.
  18. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Wow... I feel lucky if I see over 45 MPG average for the day. ;)
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Thanks for the update, Jimmy. Very nice to see you here again.
