Generic problem but would like Prius-mindset answers
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by nhguy78, Oct 15, 2013.
  1. nhguy78
    nhguy78 whirr...........
    51
    Hudson, NH
    I got metal stuck in rear passenger tire sidewall. Got it eventually towed to Sears. Ended up replacing all tires, kinda borderline treadwear going into winter. Alignment performed also. Everything seems to be good except that the vehicle makes soft thumping sound when I turn, mostly to the right. Steering wheel does not shake. Cold tire pressures seem to be accurate (35 front, between 33-35 in rear). I took it back to get it checked out. Their response after looking at it disconcerts me: They bent the backing plate a little and took it out for a drive and didn't hear anything. On the way to work yesterday, it still make the sounds. The vehicle is a 2012 Prius Plugin Advanced. I've had it less than a year. Surely wheel bearings would still be good.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Why are you taking a 2012 to Sears? Fine for tires, but get it to the dealer for anything else. Also there was no need for an alignment, and its hard telling what they might have screwed up.
  3. Cape Codder
    Cape Codder Junior Member
    22
    2013 Prius v wagon
    Does your Prius have alloy wheels, or regular wheels with hubcaps?
    If hubcaps, remove and test drive. If that stops the noise, make sure wheels are clean, and hubcaps too, and re-install. (clean meaning no dust, mud or rust)
  4. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    "soft thumping sound when I turn, mostly to the right"
    Sounds like it might be something going on with a tire. Have they been on the shelf for a long time? Flat spot? Defect in manufacture? Try rotating the tires to see if the noise changes.
  5. nhguy78
    51
    Hudson, NH
    Date of manufacture code is 1713. Regular wheels. I got a scare when I realized that the steering wheel didn't lock. It's not something I would notice regularly. I've been told, though, that Prius' steering wheels don't lock. We may end up talking to them once more but otherwise, we're heading to Toyota of Nashua to get the alignment checked.
