GenII to C mpg comparison?
Discussion in 'Prius c Fuel Economy' started by PA Prius, Mar 27, 2012.
  1. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Can you please respond if you had a Gen II and are now driving a C. I would like to know how the mpg compares between the two. Only reply if you are driving the C in a similar way you drove your Gen II, similar psi, etc. Thanks in advance!
    PA P
  2. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    I too would like to know if a C is better or worse in the real world compared to the GenII.
    I average pretty fair numbers in my GenII, and wonder if I might do better with the C.
  3. pippijones
    pippijones Junior Member
    63
    Philadelphia, PA
    I went from a 2004 Prius to a Prius C, I drive my Prii really rough and I was having problems with my 2004 before I traded it but when it was running in its prime I was getting 40 - 42. Now with the C I'm getting 42 - 45. Which isn't a great improvement, but like I said I drive them a little rough. I've seen others post a much higher gap between the two cars.
  4. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
