GENUINE Toyota Air Filter for 08 Prius
Discussion in 'Gen 2 Prius Main Forum' started by hans_fh, Nov 30, 2009.
  1. hans_fh
    hans_fh New Member
    51
    Hey guys! I just found the Prius 2008 with 25000 miles needs to replace the air filter. The dealer asked for $30 (labor included) and I think it does not make any sense. So I decided to change it on my own. But the problem is, where can I get it. Should I order the part directly from the dealer, or is there any reliable online seller that you can recommend?
    Or do you recommend me to purchase other brand instead of Toyota?
    Thanks!
  2. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Ring around a few dealers and see what price you can get (for part only). There is practically zero labor involved in putting it in.
  3. Patrick Wong
    18,200
    6,493
    You'll probably pay ~$20+ if you buy the filter from a local dealer.
    If you order online, you can buy the filter for around $14 plus shipping from a number of Toyota dealers that sell parts @ ~25% discount from MSRP. For example:
    Champion ToyotaWorld
    However, there's a minimum shipping charge of around $10 so buying online doesn't make sense unless you buy a large enough $ value of parts to leverage the shipping charge. For example, you can stock up on engine oil filters, cabin air filters, windshield wiper blade inserts, accessories such as all-weather mats, etc.
  4. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    All-weather mats!!! Are you trying to kill him!?! ;)
  5. Patrick Wong
    18,200
    6,493
    Hey, then he can get a free all-weather mat update later in 2010, when Toyota makes those available via SSC. (The mats probably are no longer available for sale now.)
  6. hans_fh
    hans_fh New Member
    51
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
  8. mike lipke
    mike lipke New Member
    89
    MN
    Any local auto parts store can get and sell you an air filter for 10-14 dollars. I wouldn't waste the gas going to a dealer for one.
    Good Lord. It is just an air filter. If they told me to use only Toyota Gas, I wouldn't do it either. Why, I might even use Mobil, Shell, Havoline, Valvoline, TropArtic oil. I use "aftermarket" tires as well, so I wouldn't worry about and aftermarket air filter.
