Gerrrrrrr: tire pressure, again
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, May 18, 2016.
  1. bwilson4web
    15,522
    Last night, I noticed a headlight burned out. Normally I would have fixed it myself but I've been busy. So this morning, I dropped the car off at Toyota for an oil change and headlight repair. But after paying the bill, I noticed they had "adjusted the tire pressure." I am sure they do it to piss me off! Sure enough when taking the dogs to the dog-park, I could feel the car drag. But I'm not going to fix it until Friday.
    I knew the front tires needed replacing so I ordered a Tire Rack pair for delivery to the walking-distance, Firestone facility. They should be there Friday and I'll drop the car off in the afternoon. I should get the car back that evening or early Saturday morning. Firestone is good about letting me inflate them.
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    The dealer will typically set tire pressure to the door jamb value to protect them from any liability issues. Annoying? - yes.
  3. qdllc
    qdllc Senior Member
    1,370
    399
    You should specify at drop-off that your TP is X and they are not to adjust it. If they do, they have been warned and you can rip them a new donkey over it.
    ETP likes this.
  4. bwilson4web
    15,522
    Uh, I try not to scold my dogs when they do something bad. Worse, the b*stards reset the low tire pressure value so I would not see they had lowered it. <SIGH>
    ETP likes this.
  5. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    yep, I tell them to change the Earl and do not touch anything else or I will go postal on them. I always wear the hat "this disabled vet is medicated for your protection"
    If you piss me off I will quit taking my meds.
  6. bwilson4web
    15,522
    Hummmmm, next time I think the tire pressure reset switch might be 'bad.' <GRINS>
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Bob, I feel your pain. Got my oil changed Monday at a trusted local shop, sure enough they adjusted my tire pressure.
    I feel like that should be an unspoken rule; never let air out of a Prius owners tire, we run high psi for a reason!
    I could feel the car dragging and my mpg dropping as I drove
  8. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    This is a case of "you catch more bee's with honey than vinegar", being rude to a service person isn't a good move, or it's the opposite of a good move, simply readjust the pressure yourself, grin and bear it.
    mmmodem and kc5dlo like this.
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Better than the tyre shop, where the tech DID NOT even look at the tyre pressure when doing the "free tyre rotation". Just wrote in the placard hanging from the rear view mirror what the door sticker read. Oh well, I had 40 PSI in the fronts and 38 in the rears, and after I left I had 38 in the front and 40 in the rears, so at least they did rotate them. ;)
  10. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    same goes for food joints.
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
  12. qdllc
    qdllc Senior Member
    1,370
    399
    You don't need to be rude, but if you give specific instructions to the service manager and the tech violates them, you have every reason to berate the service manager for failing to see that your instructions were followed. They had their chance to do the job right, they failed.
    It's the same reason you have to specify "hand tighten lug nuts" when getting tire work done. Some idiot (in spite of common practice) will try doing it faster with the impact gun. If they strip the bolts doing it the wrong way, you have them on the hook if you specifically told them NOT to do that. Don't tell them and some will try to weasel out of screwing up the job.
  13. Mendel Leisk
    38,725
    Some times you can't win: I've watched Costco's tire shop hand-torqueing lug nuts, going around in sequence, instead of the guidance to torque in a star-pattern. I'd guess they're just fine, but who knows. Why not just do it right?
  14. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Unless you do everything yourself, the best you can do is ask the service manager to annotate the work order with the desired pressure or to simply leave the pressure alone. Since I now have a new set of tires from Costco and rotations are on a different schedule as a result, I'll be asking my Toyota dealer not to rotate the tires or adjust the air pressure when I take it to them for oil changes.
