Getting 2010 Towed... Wheel lift truck okay?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by going red baby!, Jul 30, 2016.
  1. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    I thought I had read that you should have a flatbed tow the car, but I see in the manual and on here that a wheel lift truck is okay... so this type of truck is okay? :
    I believe it is my inverter. The car will go into accessory mode but won't shift into gear, won't let me drive. It appears to go into neutral fine as when I took the parking brake off it rolled a little on its own and told me to shift into P to start it.
    I just want to be sure I don't let the car get messed up. Thanks!
  2. JC91006
    16,482
    8,400
    Best to get flat bed, the bottom of the car will get scraped up from all the bumps on the road. The car is just too low to the ground
    going red baby! likes this.
  3. going red baby!
    610
    96
    Los Angeles
    Okay, thanks! AAA said it's no problem to get a flatbed. I wasn't sure if they were going to charge me for that.
    Nice doggie! :) The one in my pic is my neighbor's but I had 2 pitties before and they were the best! <3
  4. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Disconnect and reconnect the ground wire of your 12V battery and then try to start the car. Try to start three times.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    look up the codes with a good scanner
  6. going red baby!
    610
    96
    Los Angeles
    Already had it towed, but thanks! Will try that if the need arises in the future.
    Yeah, I did and got the same codes someone else got that had an inverter problem. It was in a "Check Hybrid System" thread posted recently. Thanks!
  7. tankyuong
    1,555
    660
    Central MO
    for future reference it's ok to use regular towing too
  8. qdllc
    qdllc Senior Member
    1,370
    399
    Ideally, even a regular tow truck should only lift the drive wheels enough to do the job. So, no real danger of bumper scrapes, but you can bet they won't own it if they hit a bump or a steep curb and screw up the rear of the car. I'm surprised they are used for anything these days other than moving total wrecks.
