Getting 62 MPG in my revived 2003 Prius
Discussion in 'Generation 1 Prius Discussion' started by orange4boy, Apr 24, 2010.
  1. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    A few aero mods, a bit of learning and little help from my friends.
    62 mpg 420 miles, 6.77 gallons and $25. That's 3.8 L/100Km for my fellow Canadians.
    Thanks to all the helpful Prius chatters. You know who you are.
  2. Tideland Prius
    16,615
    wow! That's Gen 2/3 territory. Congrats!
  3. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    That's with 2 passengers, 1 22lb Jack Russel, 2 60lb deep cycle batteries and misc. luggage.
    This is how I manage it:
    Techniques:
    P&G when below 64 KPH
    Keeping to 55 mph and below without inducing major road rage. "Only in Canada you say? Pity"
    Timing lights and avoiding the brakes
    Maximizing momentum
    Safe drafting when possible
    Engaging regen with brake pulse then backing off. Seems to reduce friction brake losses.
    Shift to neutral at lights. Saves ~1 amp.
    Current Mods:
    Basjoosed hood and headlights with closed cell foam tape.
    Grille block. Internal, upper and lower.
    Engine bay / hood insulation.
    Type WS transaxle oil (to replace type IV)
    Windshield rain deflectors removed (front windshield was replaced without rain gutters)
    Low profile wipers
    Custom stainless 18" screw on mooneyes
    Front air dam
    4" Side kilts
    Traction battery pre-heater
    Front air dam
    5-20 synthetic.
    Nokian WRg2 52 psi front, 50 psi rear.
    12V system run with deep cycle batteries
    750 watt transaxle block circulation tank heater
    1500 watt engine block circulation tank heater. 70 - 90˚C Operating temp at start.
    Planned Mods:
    Regen boost circuit (autospeed article)
    Rear stainless wheel skirts
    Rear wheel boattails
    Belly pan upgrades
    Optimize front air dam transition
    Active grille block using electric antenna hack.
    Rear fastback conversion with plexi
    Basjoos door gaps with foam tape
    WHCSC likes this.
  4. Tideland Prius
    16,615
    holy cow that's a lot of mods.
    I ran 38/36 on Integritys on the 2005 Prius and got a 3.9L/100km tank. Shows you the advances of the Gen 2 over the Gen 1! I can't wait to see what you'd get on a Gen 2 or 3 (3.5? 3.0?)
  5. bwilson4web
    16,363
    Excellent list:
    That is "~1 amp" of traction battery current or aux battery?
    I've been looking at a little simpler system based upon the accelerator automatically shifting into "N" when released and back into "D," if already in accelerator "N," for brake. Alternatively, shift to "B" to soften traction battery charging. This needs study and of course, careful testing. One thing that pops out is a smarter cruise control: (1) slacks off up grade, and (2) speeds under 23 mph (37 kph.)
    Other than Yankees tourists, is it possible to piss-off a Canadian?
    Impressive tires!
    Normal USA circuits are 15 A @120 VAC ~= 1800 W. Do you have a single, 20/30 A service plug? Or are these 220 V. heaters?
    Do you have a warm-up protocol ... say 1-4 hours before driving?
    I've been following your progress from transaxle replacement and many of the other changes. This journey would make an excellent web page, a 'how to do it.' <GRINS> So you got the car back in September and this is after 6-7 months?
    BTW, I wouldn't worry too much about going with an NHW20, not that they didn't do some good stuff and it is a larger vehicle with more space. A lot of that can be mitigated by simply removing the rear seat back and not bolting it back in. This would let you put in oversized loads.
    All in all, an excellent effort.
  6. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    One amp from the traction battery as read by the Graham scanner.
    I get away with one 15A outlet. One plug for the 1500W the other for the 750W tank and the 200W battery warmer. I think they must pull a bit less than their ratings.
  7. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I bet with the addition of an Enginer plug-in kit you could reach or exceed 100 mpg.
  8. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    It's on the list. Perhaps this fall. I will probably go with lead acid though. I'm not liking what I'm seeing with their BMS and the failure rate of the lithium cells. I can always upgrade later as well. Plus I already have a set of lead acid cells here for my other EVs.
    Fun fun fun.
  9. adric22
    642
    146
    Fort Worth, TX
    Well, I have the Enginer kit in mine 2002 model. I only spent $1,500 on the kit and I average 74 mpg city/highway. I haven't had any trouble with the BMS but I also check on the charging periodically and if the balancers are beeping, I unplug it.
  10. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    What's the max sidewall pressure on those tires?
  11. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    51 psi. max sidewall. And oops, I bunged up that entry. 52 psi front, 50 rear. Where did that 65 come from?
    Edited.
    Sweet! I'm going to hit 74mpg combined first then get the kit. I like a challenge. And I'm crazy like that.
    2 people like this.
  12. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I'd love to see pics of these mods.
