Getting a "Check Hybrid System" after cleaning the cooling fan
Discussion in 'Gen 3 Prius Technical Discussion' started by Priusbill1, Jul 17, 2025 at 4:20 PM.
  1. Priusbill1
    Priusbill1 Junior Member
    Murrells Inlet, SC
    I watched a couple of You Tube videos about cleaning the fan on a Gen 3 Prius, 2012, 212,000 miles and had never been cleaned. Everything went as expected and when I finished the job, the car wouldn't start and had a Check Hybrid System warning light on the dash. I removed the orange safety disconnect before I started and reinstalled it. After getting the message, I removed it and reinstalled it again to make sure I had it installed correctly, but got the same message. Other than the cooling fan, I didn't touch anything else on the hybrid battery. What could be wrong? What can I check? I can't even drive the car at this point, it won't allow me to put the car in gear.
  2. xliderider
    xliderider Senior Member
    8,065
    3,227
    Honolulu, HI
    Did you properly connect the orange safety connector? You have to push it down until it clicks after rotating the lever up 90 degrees, many forget the second step.
    If you do that correctly and still get the Check Hybrid error, disconnect the negative ground cable from the battery to the body, wait 5 minutes, then reconnect. Then try to power the car on again.
    SM-S936U ?
    #2 xliderider, Jul 17, 2025 at 5:32 PM
