Getting access to the exhaust manifold to check for leaks
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ashyukun, Nov 14, 2014.
  1. Ashyukun
    Ashyukun Junior Member
    38
    Lexington, KY
    I'm trying to chase down the cause of a P0420 code and make sure there isn't anything else causing it before I take the rather hefty financial hit of replacing the cat. Since it's the first Prius I've ever even been around when running I can't tell if its exhaust makes more noise than it should, but it has always seemed to me that it makes more noise up near the engine than it should, so I'm planning (well, 'fogging' is probably more accurate given my plan...) on smoking the intake and exhaust. The intake is fairly easy- but the exhaust, the exhaust manifold is rather buried. Do I just need to take the cowling off so I can look down at it and see if it's leaking anywhere? I'm assuming I won't be able to see it completely from just down below it...
    Thanks!
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    you'll get a pretty good look from underneath, not much in the way.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    How many miles on car and how rusted is the chassis?
  4. Ashyukun
    38
    Lexington, KY
    264k, and actually I don't recall it being very rusty at all.
