Getting all doors to unlock
Discussion in 'Gen 2 Prius Main Forum' started by IABoy987, Sep 21, 2012.
  1. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    I believe that when you double push the fob unlock button all four doors unlock, however just coming up to your Prius will just unlock the driver side only. Wondered if there is a "secret" combination of pedal pushes, light switch/windshield on/offs that reprograms the Prius to make all four doors unlock everytime?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Press and hold the lock + panic button together for 5 seconds when the car's off to switch between the 3 modes.
    It should be on page 32 of your manual.
    PriusPilot84, IABoy987 and edthefox5 like this.
  3. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    Thank you!!
  4. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
    Ok I did the "unlock all doors" change to my smartkey system the other day but I have another question relating to it - how close do you have to get to the car for the smartkey to unlock the doors? I have to literally lean against the cars door with the FOB in my pocket for the smartkey to get recognized and the doors to unlock. Is that normal?
  5. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    When did you last change the fob battery? The fob transmitter isn't very strong I found, and changing the battery about once a year seemed to fix the problem you described.
  6. PriusGuy32
    1,417
    512
    Ahhhh...Thanks. I just bought the car 2 weeks ago - Ill bet the batteries are originals from 2007!
  7. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    I seem to remember my 2007 Gen II had two or three discrete li'l black buttons directly below the steering wheel column, above where the driver's shins would be when seated. One of these buttons when either depressed or extended (spring-loaded button lock) controlled which doors were opened electrically, whether by pushing the black rubber square on the door handle or by the fob. Kind of tricky to find the 1st time. The manual had door setting instructions once you located the buttons.
    I set the door handle buttons on all three main doors to open & lock all three doors. I remember that one of the buttons also switched all the proximity sensors for the Gen II on & off if you left it parked at an airport economy lot for, say, three+ weeks, to not drain the auxiliary car battery. Of course, that was back in '07, and the details are dim for me now.
  8. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    2007 Prius Owner's Manual only shows the SKS on/off button where you describe. See page 34 in link here; http://www.toyota.com/t3Portal/document/om/OM47568U/pdf/02-01.pdf
    The usual procedure of Press and hold the lock + panic button together for 5 seconds is on page 32 in the link above, like cwerdna wrote in post #2.
    I like extra buttons so I went out to look in wife's 2008 Gen II and found two buttons where you describe them. One to turn SKS on/off, and one to set the Tire Pressure Monitoring System after you have the tires set to the pressure you want.
  9. wgary
    wgary Member
    37
    36
    Auburn, Alabama USA
