getting an extra copy of key for my prius c 2015
Discussion in 'Prius c Main Forum' started by Hui, Apr 10, 2019.
  1. Hui
    Hui Junior Member
    Surrey, BC
    2015 Prius c
    hi folks:
    my car is 2015 prius city and I only get one key .Now, I am thinking about getting an extra one just in case.
    I do not need key with fob , just a regular plain car to open the door and drive the car. I've called dealer and they
    charge over 400 Canadian for a fob key with programming..
    Is there anything I can do to save the 400 bucks? Also what's the difference between dealer and DIY?
    Thanks
    Hui
  2. Hui
    Hui Junior Member
    Surrey, BC
    2015 Prius c
    I saw some people say I need to have Toyota G chip key, but my original key has H at the blade, does that mean H chip instead of G chip/ thx
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    IF......the FOB must be present for the car to start.....then you DO need a spare FOB too because if you lose the last one it will cost you about TWICE the $400 to get your car to run again and you will have no options.
    Call around to some local locksmiths.
    If they can do it, the price will be about half what the dealer wants.
  4. Hui
    Hui Junior Member
    Surrey, BC
    2015 Prius c
    thanks, also my original key has H on it. Does that mean it is H chip instead of G?
  5. sam spade 2
    7,035
    2,790
    2017 Prius c
    Have NO idea.
    If it is stamped into the metal key, my guess is that it refers to the key blank.
    But that is just a guess.
  6. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    Mine also says "H". I now wonder if all of them will say "H". This is the kind of key/fob I have:
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    You need to go to the Toyota Owners website. Put your VIN# in and see if your car has Toyota's anti-theft device installed. (Pretty sure it's standard equipment). If it does, then be sure to get a chipped key.
    Welcome to Toyota Owners
    Oh my key also has "H" stamped on it in case everyone else may be wondering.
  8. Issy Car
    Issy Car Member
    56
    48
    Vancouver Canada
    2015 Prius c
    I think the G or H just tells the dealer which kind of chip is in the key. Either way, everyone else is correct, you will be needing to go to the dealer to get it programmed. The chip inside the key is RFID so it needs to be programmed.
    Although I've never done it, you could try a local locksmith and ask whether or not they can program a key for you. No idea how much but I wouldn't leave before verifying it will work every time.
    When I got a second key from Richmond Toyota (I see you're in Surrey), they had to pull out their laptop and plug it into the car to program the new key.
  9. Ryan E Yip
    Ryan E Yip New Member
    San Francisco
    2015 Prius c
    Car Key Express made my non Smart key remote for $150. Apparently they are the subcontractor for the Toyota dealers. I bought the 3-yr warranty just in case.
