Getting horrible fuel economy
Discussion in 'Gen 2 Prius Fuel Economy' started by jamesrm, Jan 20, 2009.
  1. jamesrm
    jamesrm Junior Member
    Mid TN
    I have had my 08 Prius since April, 08 and its gotten atleast 45-48 mpg. Last 4 or 5 tanks its been steadily declining, to now I am getting 300-350 miles per tank when I used to get atleast 450. I used to not loose the first gas pip until like 120 miles, now I loose it at 60-70....
    Any ideas? It has 20,800 miles, brand new tires (this tank, had a blowout), new oil every 5k, new oil filter and new air filter.:eek: Air pressure has been constant at around 40psi. This might have happened around the oil change, but I am using the same viscosity I have always used, 0W-30 synthetic.
  2. Bob64
    1,540
    92
    Virginia
    cold weather destroys mileage.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You have indeed found the Achilles Heel of the Prius!!!
    Even here in Sunny Los Angeles, when it gets cool, (I won't offend anyone who has to deal with -35 actual by saying cold) temps in the morning 40's, my milage took a hit!!!
    Now that we are back to 80's in day and 60 at night it has returned to "Normal"
    Next week winter returns, OK just a little rain, and 50's. However I see another milage hit coming my way!!
    73's de Pat KK6PD
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    jamesrm,
    You might want to check your oil level.
    Posters have reported that "overfilling" up to the High mark on the dipstick,
    the full recommended 3.9 qts IIRC, can result in lowered FE/MPGs.
    Likewise posters say that refilling the oil to midway between the High and Low
    marks on the dipstick, about 3.5 qts, is as "full" as the crankcase needs to be.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Cold weather is not just the Achilles heel of the Prius, it's the Achilles heel of all internal combustion powered cars. Winter mileage drops in all normal cars, but it's easier to see in the Prius due to higher mileage and better instrumentation.
    Tom
  6. someguy51
    someguy51 New Member
    Calgary, AB Canada
    I'm too scared to check my fuel economy since winter came. I used to get 5.2 L/100 KM (about 45mpg) but I've noticed that you have to drive the car around for quite a while before it will stop idling at red lights when its colder then -20 C.
  7. jamesrm
    Mid TN
    Haha, thanks guys, thought that might be it but I was shocked how hard of a hit it was. I ordered a glow plug today.
  8. qbee42
    18,058
    3,074
    Northern Michigan
    Do you mean a block heater? Glow plugs are used to start diesel engines.
    Tom
  9. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    Batteries don't like cold weather either. And since the Prius doesn't turn off the ICE until it and the exhaust are warm, temperatures have a bigger effect on the Prius than on cars that always run the ICE anyway, cold or warm.
  10. pepper04
    pepper04 New Member
    boston, ma
    :( I've had my car for three years and have driven it through 2 prior winters- it's an '04 Prius and has 67,000 miles on it- and a few months ago my car suddenly started getting 20-25 mpg when before it has always gotten about 40-45 mpg. I've taken it to the Toyota dealership several times and have been told that nothing is wrong with my car and that it is just the cold weather, but I find it strange that this did not happen the last two winters and also a little frustrating since no one can give me a good explanation.
  11. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    A tough hit for all of us - but worth giving some thought on qbee2's comments that it's, '...easier to see in the Prius due to higher mileage'.
    Your approximate drop from 450 miles per (say) 9 gallon tank to 350 miles mean that you are roughly now using just over 0.5 gallon more gas for every 100 miles (50 mpg dropping to 39 mpg).
    However, if a 'normal' car dropped its mileage from 30 mpg to 20 mpg, this is equivalent increasing its gas consumption by 1.67 gallons for every 100 miles - more than three times more gas used compared to you, even though both experience around a 10 mpg drop.
    Perhaps our hit is not as bad as for many others!
    (More on this concept on the fourth 'sticky' of this forum!)
  12. elcorazon
    elcorazon New Member
    74
    chicagoland
    I wish I did so well.
  13. Bob64
    1,540
    92
    Virginia
    What is your outdoor temps right now?
    How long are your trips?
    Do you use the heat?
    Are you grill blocking?
    Have you checked your tire pressures? What about engine oil level? Also check your cabin air filter.
  14. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    The OP mentioned that he just put on new tires. He didn't say what kind. Mileage in the Prius is very tire-type sensitive. I agree with the other comments about how cold weather affects mileage in a seriously detrimental way also, as do short trips, but tires are also sometimes a factor.
  15. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Cold weather factors:
    1. Cold ICE and coolant require the ICE to operate just to keep the engine warm.
    2. Many humans find the need for some heat as well...this means the ICE runs more and hurts mileage. (Defrost will hurt it even more.)
    3. The battery is cold and part of the cold weather idle cycle seems to revolve around charging the battery to warm it initially. (This is my synthesis of some info I've read recently about battery response to temperature. If it is incorrect hopefully a guru will correct me.)
    4. The gas tank bladder shrinks in cold weather, reducing the amount of gas that can be added and therefore the range between fills. By my calcs this can be up to 15% in my locale. This doesn't impact real mileage, but does result in annoyingly short range, especially when combined with other factors above. This is likely to be most obvious on the first pip and perhaps the bottom. I've noticed a reduction on the top pip, but that might be specific to my car.
    5. Standing snow/water etc. will also reduce mileage (rolling resistance increases.)
    6. Cold, dense air (and higher pressure in the cold fronts to a lesser degree) will also increase aerodynamic drag at highway speeds.
  16. richard schumacher
    7,663
    1,038
    United States
    What are the pressures in the tires on a cold morning, before you drive anywhere?
  17. Helio
    Helio Member
    173
    Columbus, OH
    Don't feel so bad, my 2007 is getting 38.7 right now. I even have an engine block heater! But, to the Prius' defense, I live 3.3 miles from work, I do not have the grill blocked, and I have been driving back and forth to Children Hospital (sometimes twice a day) for the last 22 days and it's only 6 blocks away. Those 3 things will kill mileage.
    And no, I'm not going to walk to the hospital if it's dark. I have to walk through the 'hood.
  18. VAJen
    VAJen New Member
    Virginia
    I have an '06 Prius. I used to get 55/mpg until I had a new set of tires put on at 40k miles. Since then I have been getting around 45/mpg. Since the weather has gotten cold, I've been getting anywhere from 36 to 42/mpg. So.............it seems tires and weather have something to do with it.
  19. Snagtooth
    Snagtooth Junior Member
    63
    Columbus, OH
    Had to LOL at that. I live in the central OH area myself. Even when I was a child and came to that hospital for visits to my younger brother - it was a rough neighborhood. Some things never change. So no, I don't blame you one bit for not walking!
  20. butchbs1985
    butchbs1985 Taking things apart is fun!
    229
    16
    ChicagoLand
    2013 Prius v wagon
    IMHO no really good reason for that kind of drop. In Chicago, I've averaged 39 - 42 mpg over the last two weeks and the temps have ranged from -15 to 30 (Fahrenheit). Regarding what I do, i'll answer Bob64's questions below.
    1. It is 35 miles to work. Then I drive for work anywhere from 1 - 70 miles away.
    2. I keep it on AC / Auto set to 70 degrees.... Comfy:D
    3. Definitely grille block below 40 degrees. (Never been to socal so I don't know how cold it is).
    3. Tires at 44/42. Oil never above 3/4 and never below 1/2 full. Filter change spring, summer, and fall.
    Once the temp is consistently above 50 and below 80, i'll average 52 - 54 then once it's above 80, the A/C will limit my mileage to 48 - 50. Comfy again.:D
    I would also recommend checking the MAF as it can impair mileage. Have you ever checked your plugs? I replaced mine at 60k but they didn't look that bad.
    EDIT: Sorry to the OP as I see you are in TN rather than socal. I was thinking back to the previous thread that I was reading.
