Getting my 2006 inspected
Discussion in 'Gen 2 Prius Technical Discussion' started by boppo, May 4, 2011.
  1. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Last year when I was getting it inspected at a friends local shop and he had it hooked up to the computer the engine shutoff. He was able to get the info he needed to pass the test. This year I think I should leave the lights and air on while he runs the test so the engine keeps running until the test is over. Is that the right thing to do while it is hooked up to the NYS inspection computer?
    Thanks
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    One trick you could do is use the 'N' position of the 'gear' selector - if the engine is on when you shift into 'N' it will stay on (and not charge the traction battery, so don't leave it like that for a long time).
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is a maintenance technique to force the ICE to idle. See the attached file.
    JeffD
    2 people like this.
  4. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Two years running I have taken the car in, asked for an inspection, and driven away with a sticker. I don't think you have anything to worry about.
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I just had my car inspected in Port Jervis at a local shop. My experience is the same as brick. Drove in and drove out 20 minutes later with a sticker. I'd think that most inspection places are used to doing a Prius since they've been around for 10 years (I think).
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    From wikipedia:
    No need to run engine for emission test.
  7. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Thanks for all the replies.
