Getting ready to do the EV mode and need help on the white bar.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by boppo, Jun 27, 2009.
  1. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I will be getting my kit soon so I printed out the PDF install file. I took all the stuff off and unplugged the gray connector. I found the 2 wires to tap into and where to put the contact. What I am having problems with is the lifting of the white bar. Can anyone that has done this help me since it just looks like a white plastic square and I don't see how to lift it. I DONOT want to screw it up.
    Thanks
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    There should be a small place you can fit a very small screw driver or a paperclip in and pry it up. It only lifts up about 1 or 2 milimeters so dont force it.
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
    TheForce, Thanks for your reply.
    I am looking at a little 1 milimeter white square
    , I guess I don't see how it lefts up.
    I think I messed it up.
  4. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Well I got it today and hooked it up and it seems to work, at least in the garage the ICE will not come on when I move it around.
    Thanks
