Getting Replacement Keys...Yikes!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by George Clint, Jan 16, 2019.
  1. George Clint
    George Clint New Member
    I'm new to this forum...what took me so long? I'm the original owner of a 2004 Prius. I had two keys.
    One has part of the top missing and is pretty thrashed from dropping it over the years and it's protected
    by some electrical tape, but it still works. The other even after replacing the battery still doesn't work.
    All I wanted to do was get a replacement key for that one using the thrashed one as a backup, but the dealer
    told me the car would have to be re-programmed for about $150 and each new key would cost $250 of course making my thrashed one useless because of the re-programming. in other words, for two new keys
    and the rest: about $650! Is there any other way around this without having to be a master tech guy?
    George
  2. JC91006
    16,829
    8,601
    If the thrashed one is fully functional (the lock button works), then you can self program a new key with it.
    Just buy a new key online and DIY
    M in KC and srellim234 like this.
  3. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
  4. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    In addition to the tips regarding a new key you can also replace the case of the working key very cheaply and it's easy to do. I recently replaced both of our cases for $9.99 each with the USARemote fits Toyota Prius Key Fob Cover Case from Amazon.
    Make sure you transfer three things from your old, taped case to the new one.
    1. The circuit board
    2. The little black RFID chip
    3. The metal mechanical key.
    Skibob and JC91006 like this.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
  6. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    I would replace the case transferring the electronics over.
  7. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    and don't forget the RFID chip in the front of the bottom half.
    It is also possible to buy just an empty case (with or without the key blank) from the dealer if you want to just replace your case. Then there are all the cheap Chinese knock-offs all over the internet.
