getting your mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by feethanddooth, Mar 1, 2005.
  1. feethanddooth
    feethanddooth New Member
    31
    new jersey
    is there a way to get your over all mpg from the computer? ive hit reset so may times and have not recorded it that i have no idea where i stand over all. thanks
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I love your signature. I smile every time I look at it.
    I hope you smile too. I hope you smile a lot. I hope you don't stop smiling when you read that any tank information not recorded is lost for ever. Sorry.
    Have I mentioned that I love your signature?
    Smile.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Many different people have as many different ways to record their overall mileage. You can click on my mileage in my signature and see the excel spreadsheet I use. If you like it, I can email it to you.
    When I get gas, I write on the receipt the tank mileage from ODO2 and the MFD's reported mileage. The gas receipt itself has printed on it the number of gallons and the date. I use those four pieces of information to populate the database. Oh yeah, of course I reset the ODO2 and the MFD before I leave the gas station.
    You might want to build a spreadsheet of your own with your own level of detail.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I see a lot of variability between the computer and the pump. I have to say that in Washington the State trust the pump repair and installation technicians to set up the pumps in our state. I have no idea who they work for. The state have very few inspectors to check pumps and they check pumps infrequently. One of the pumps I use has no sticker at all other have inspection stickers that are 3-5 years from today's date. I have little trust in the pump gallons, and after several calls to the State Department of Agriculture they really don't care either. So believe what you will.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    Henry, its the State Weights and Measures that is responsible for calibrating gas pumps and mandates say it will be done every 3 years for every pump in the state.
    well as you know by now, that aint gonna happen. the entire state has 9 inspectors and they pretty much only do complaints now. they do regular inspections if they have no complaints, but i reported a pump on the west side arco by the courthouse and was told that they were about 6-10 weeks behind in getting to the complaints. i filed the complaint in sept and still have not heard a thing.
    i determined the pump was shorting people by the computer reading being significantly over 3 times in a row. i guess that is how the station can get away with being the cheapest in town.
    btw. at any other pump, the computer reading is high one time, low the next. you can see by my signature that over time, there seems to be little difference in the readings as the averages overcome the most likely less than full tank the car was delivered with.
    also... most recent inspection sticker i have seen in the state of WA... june 2000
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    "Henry, its the State Weights and Measures that is responsible for calibrating gas pumps and mandates say it will be done every 3 years for every pump in the state" That is correct but I called them and they are part of the Department of Agriculture. I called them when one of the stations I used installed new pumps and there were no stickers at all on the pumps. It may average but I don't trust them.
