Glare along rear defogger lines after tint
Discussion in 'Gen 3 Prius Accessories and Modifications' started by umichioe, Nov 9, 2012.
  1. umichioe
    umichioe Junior Member
    77
    I tinted my Prius v's rear hatch window with SunTek CXP film yesterday morning. When driving at night with the tinted window, there are streaks of glare along rear defogger lines caused by the headlights behind me.
    For v owner with tinted hatch window, do you have the same issue? Will the glare be gone after the tint dries up?
    I know I am posted in the Prius Forum. Just want to get some general idea as I think the defogger should be similar between Prius 3rd Gen and v.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That's normal. When the excess water dries out it will be better/gone. You can speed up the drying process by parking in the sun.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yep, that normal
  4. umichioe
    77
    Hi Sean,
    Do you mean it is normal for the glare to be there initially? Or it is normal to have the glare even when the tint is settled?
    Thanks.
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    The excess water under the tint is acting like a prism and causing the light to refract along the defroster lines. That is the glare you are referring to.
    Let the tint dry out and don't worry about it. As mentioned previously, leave it out in the sun to speed up the drying process.
  6. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I'll third the "normal". Every car I've ever tinted, with the exception of the Phaeton, exhibited the same thing.
    Having said that, depending on where you live it could take a while -- especially at this time of year. (And, by "a while", I mean weeks.)
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Every car I have had tinted has always had this issue. It's at it's worst when u first have the tint put on. It will get better but will never be what it was prior to being tinted if u have the defroster lines on the glass..........at least that's been my experience from several cars
    Nova
    325e
    Accord
    Yukon Denali
    325i
    525i
    M3
    Escalade
    Gen2 Prius
    CTS
    Gen3 Prius
  8. RCDrifter
    RCDrifter Junior Member
    Southern California
    You may want to avoid using your rear defroster untill it goes away. Sometimes the heat can cause bubbles to form or the adhesive to loose effectiveness. Also, dont leave the defrosters on for too long, it can cause premature peeling.
