Glare off cup holder solutions???
Discussion in 'Prius v Main Forum' started by moparjer, Jul 28, 2013.
  1. moparjer
    moparjer Junior Member
    Oregon
    Okay, I know I am being picky, but the one thing that drives me nuts about my Prius v 5 wagon is the amount of glare that the shiny silver ring around the console cup holder reflects when the sun hits it which is all the time in the summer. Of all the materials available why Toyota engineers decided to use a bright shiny material is beyond me. Recently, on a long trip I put my e-reader, my wife's purse, A&W napkins, etc., over the cup holder to cut the glare. I even considered taking a black sharpie to it before coming to my senses.
    Zoltani likes this.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Top of the center dash is the same way. suggest tinting the windows.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    Good tint on side windows and polarizing wrap around sunglasses does the trick.
  4. PriusistingCondition
    PriusistingCondition Junior Member
    2013 Prius v wagon
    What about some Plasti Dip spray in the color of your choice on the ring? Tape off the surrounding areas and spray several thin coats for a durable thick coat. Lots of videos online with different automotive uses. I'm going to use it on my wheels soon for a darker color.
  5. Northernguy
    Northernguy Junior Member
    Really tint the windows? Sharpie? Just get yourself some polarized sunglasses or clip-ons if your wearing regular glasses, and problem solved. Sunglasses will also help you from getting cataracts later in life, so two problems solved.
  6. dwfinke
    dwfinke New Member
    With a small flat head screw driver this can be taken out. There are three tabs to watch for one at 12 oclock, 4 and 8 that holds it in. Once removed sand the plastic to remove the slick clear coat on it. Once that is done you can apply a few coats of your choice of colors in a flat spray paint designed for use on plastic. Be sure to do light coats and let dry well between coats. Then when it get beat up you can always take it out and do it again. I did this with a flat black paint in the last couple days and no more glare.
