Global Warming Question
Discussion in 'Environmental Discussion' started by FL_Prius_Driver, Aug 12, 2011.
  1. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I'm trying to find out what the expected CO2 concentration would be under any or all of the following possibilities:
    1) We continue to burn all the crude oil we will extract over the next century
    2) We eventually burn all the crude oil and coal reserves
    3) we eventually burn all the hydrocarbons (including methane)
    While there is a lot of discussion of where we stand now, I'm much more interested in where we stand at endgame.
    Thanks greatly to anyone who can help.
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    I can't really answer your question directly, but all the evidence that I see is,,, not good.
    Science stunner: On our current emissions path, CO2 levels in 2100 will hit levels last seen when the Earth was 29°F (16°C) hotter | ThinkProgress
  3. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    There are many sources of information on recoverable crude oil, methane (in those geological traps) and recoverable coal. They seem to span quite a wide range.
    I do not think there are similar estimates for tar sands, shale oil, or oceanic methane clathrates. But my impression is that this group could include much more carbon than the previous.
    I have no doubt that uncontrolled burning could put the atmosphere at 1000 ppm in the 21st century. After that the path would be much more speculative.
    But there are two other major issues to consider, at least. Will we continue to receive the same level of ecosystem services from the marine and terrestrial biosphere? Specifically, half of anthropogenic emissions are now taken out of the atmosphere by biological sequestration. If that service wanes, CO2 in the atmsphere would go much higher with the same burn rate.
    Also there are large pools or organic matter in soils (especially high-latitude soils). Probably 4 times what is in the atmosphere at present. Dissolved inorganic carbon in the surface ocean is also a large quantity, but I'd have to look that up.
    For both of these, the point is that we are quite uninformed about the stability of those C pools under climate change. They represent feedbacks that could send atmospheric CO2 to a level that nobody wants to have.
    So the original question is difficult to address. Asking it does neatly summarize why people are putting substantial effort into understanding the carbon cycle.
    My response leaves out several things, including geological sequestration by mineral weathering and ocean net trapping by large-scale changes in circulation patterns. These are among the leading processes that have greatly reduced atmospheric CO2 in the past. I have no doubt that they will 'help us out' some time in the future. But it may be a distant future.
    I do not think we will have another coal-forming period like 350 to 320 million years ago. The decomposer fungi have gotten too smart to let that happen. It really drew down the atmospheric CO2 though.
  4. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    All three of your questions depend upon a number of factors, some of which have already been addressed.
    As already stated, weather or not the biosphere continues to soak up as much of our CO2 as it does now will be a huge factor.
    But the bigger one, is 'how much oil is burned' in each of your 3 questions?
    Secondary to that is, 'how much energy/fossil fuels are required to be burned to get to that oil/shale, etc.
    As cheap oil is used up, it requires more and more energy to get to the tougher to get oil. Emitting yet more CO2 than just burning the oil itself.
  5. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I know any answer depends on an extraordinary number of assumptions and feedback mechanisms, but a couple of straightforward assumptions will give me a reference point. I'm pretty sure someone must have done something similar, but I could use help finding it since quite a few here know the best places to look or direct me.
    For example, could the total fossil fuel that could be burned adversely affect the O2 concentration?
  6. icarus
    4,884
    976
    earth
    See also Tar Sands Oil!
  7. tochatihu
    9,852
    3,814
    2001 Prius
    21% oxygen is pretty nice for us. I reckon most could get by on 18%. Much below that could be trouble.
    The element ratios work out that O2 should go down as CO2 is (net) produced by combustion. I mentioned this in a recent thread, and a few groups have actually measured the -2 ppm that is now happening to oxygen.
    A 21% to 18% reduction in O2 would correspond to CO2 increasing from the current 400 (almost) ppm range to 3%. There is no doubt enough carbon stored somewhere on the earth to cause that, but it is far beyond what anybody is planning on doing. We'd all die 6 different ways before it happened.
    So, I advise you to not be concerned about an impending oxygen shortage.
    Inside a closed garage, though, your mileage might vary.
  8. ETC(SS)
    7,355
    We used to vary O2 in submarines a bit, but I don't recall how low they used to let the values get. I'm thinking 19.something.
    -----yeah....I know. Didn't hurt me a bit, huh? :D
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I agree with your conclusion.
    I think it is the O2 partial pressure in the atmosphere that matters the most. Seems like it would be the partial pressure, or aviators using pure oxygen at high altitudes in unpressurized aircraft wouldn't work.
    The fact that most people can acclimatize to 10,000 feet elevation would indicate that we humans can get along on a lot less oxygen. At 10,000 feet the O2 partial pressure is about the same as it would be with 13% O2 at sea level.
    There are places where people live at 18,000 feet but that is extreme.
  10. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    You need to clarify a lot of things before you can even guess an answer the question. Just the concept of "all fossil fuels" is ambiguous -- there's total reserves (all the molecules in the ground), proven reserves (the fraction of that you guess you have a good chance of extracting with current technology), and then there's the fraction of that you can extract at a profit.
    That said, if you look around, everybody seems to give a figure in the 1000 to 1500 ppm range as an answer to your question. No clue as to the detail there.
    Here's a discussion. It's a little dated but is easy enough to follow:
    U.S. Global Change Research Information Office
    Here's one of our national labs, they say nearly 1500 ppm, but they explicitly model a slowdown in uptake by nature:
    What If We Burn Everything?
    And, as with anything in this area, you will find some nuts who say this is all wrong, everything will be OK, and yada yada yada. Believe them if you want.
    Getting an accurate answer is hard and will have some high degree of uncertainty.
    But you can get a feel for it yourself, by answering the simpler question. If we vaporized all our fill-in-the-blank (fossil fuels, all biosphere carbon, etc.) tomorrow, what would that do to atmospheric C02? That's easy enough to answer.
    For that, all you need is the ratio of carbon in the reservoir to carbon in the atmosphere. Using the first cite above, about halfway down the page is a list of the carbon reserves. Based on that, there's 6.6x as much carbon in fossil fuel as there currently is in the atmosphere. Vaporize that tomorrow and you'd get atmospheric C02 just over 3000 PPM (assuming I did the math right, that's 7.6 (no typo) times current C02 of 392). (392? The conventional figure is 380, but ... that was five years ago. Now it's 392.)
    The fact that the actual estimates are in-the-neighborhood-of-half of that tells you that either they start with a lower estimate of "reserves", or, more likely, on net they assume Nature ultimately absorbs about half of what we emit, pretty much the same as today.
    So you get roughly the correct answer by vaporizing existing fossil fuels today and assuming Nature absorbs half.
    None of those assumes significant positive feedback from nature -- the carbon in the arctic soils and in the methane clathrates noted above. If we get that positive feedback started in earnest, and then its hard to see where this would stop. The clathrates, in particular, have been implicated in past extinctions. Warming to methane to more warming, until all the carbon stored there comes out into the atmosphere.
    OTOH, all of these estimates assume that there will still be a civilization burning fossil fuels at some fairly advanced points in the future. Given that the same models that project the temperature rise also project that most of North America and much of Europe will be uninhabitable desert by the year 2100, I'd say that's unlikely. Google "UCAR Drought" if you want to see the best available projection of what's going to happen to America's bread basket. Tough to mine coal if you can't eat.
    So:
    1) I don't think you have to go even close to the endpoint to get (the scientific community's best estimate of) outcomes that we, as Americans, really do not want to see. Just Google UCAR Drought, and realize that the current situation in West Texas is a -4 on the scale they are plotting there. They appear to the eye to over-predict actual drought in the base period (you'd need to read the research to understand it in detail), but its the change between 2000 and 2100 that is of interest.
    1a) I think it's an academic exercise to calculate an estimate that assumes industrial society will survive the point of extracting the last bits of fossil fuel. There will be a breakdown in the social order long before then. "Let them eat cake", "bread and circuses" -- there are reasons those phrases survive. Violent revolutions correlate strongly with starving populations.
    2) With no positive feedback from nature, looks like 1000 to 1500 PPM or so covers most estimates. The Livermore National Lab projection above was something like 15 degrees F warmer than now, based on that. I hope I don't need to explain how screwed up the world would be, at that temperature.
    3) With positive feedback from nature, it's hard to place an upper limit on it. Hansen talks about Venus syndrome on earth, but I've seen some pretty smart people say that's not possible. (Basically, it gets so hot you evaporate the seas, and water vapor, being a greenhouse gas, keeps the planet locked in at that temperature.) But there's good paleological evidence for the potential for extinction from release of carbon stored in clathrates, which in this case would presumably be our extinction.
    3 people like this.
  11. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I'm trying to figure out what possible worldwide mechanism can or will be implemented to provide all the world's energy needs without burning any fossil fuel. That point of ending the burning of fossil fuel is what I call "end game" and I was trying to figure out what our CO2 concentration range might be at end game. Note that "end game" results with a lot of fossil fuel never burned and the associated industries of oil extraction, mining, oil shipping, refining, etc. eliminated.
    I don't see any mechanism that results in all significant crude oil reserves not being exploited, hence the first question. If we are trying to get to a CO2 concentration that is lower than that value of just crude oil driven CO2 concentration, that probably is going to require either wars or heavy blockade/destruction of oil extraction infrastructure. (I'm NOT wanting such evil, I just cannot figure out how to stop ALL crude extraction and burning with out force being involved. A lot of oil seems to be in countries and in corporations that will be quite happy to screw the rest of the world for the money involved.)
    The next possibility is the restriction of burning coal. I have more hope here since the US controls a large chunk of the reserves and restricting coal extraction is more enforceable among countries. But how much coal must be left in the ground to reach the levels the world can achieve, not necessarily the levels wanted. Right now we ship coal to China from the US. Do we want to stop that? Can we stop it? How would we stop it?
    One of the essential elements is global education. I'm not talking about the science vs. denier battle of climate models. Nor am I talking about using scare tactics of what particular models can show. Scaring is not Education. I'm talking about the monster levels of 1500+ ppm effects that will have a lot more indicators (on the way there) that can be used for education. To quote Tochatihu; "We'd all die 6 different ways before it happened". What are those 6 different ways?
    NOTE--The slight reduction in O2 concentration I would not expect to be a life threatening mechanism, but it is something that can be measured directly for worldwide education and may have measurable ecological signs and impacts that can be published.
  12. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Read "Storms of my Grandchildren " by James Hansen US Climatologist. for an easy to understand analysis.
  13. tochatihu
    9,852
    3,814
    2001 Prius
    We need water, food, functioning infrastructure at a variety of levels (thinking both about politics and medicine here), and manufacturing, service industries and trade to pay for it all. We have all that now, although it can easily be argued that the 'bottom billion' on the Earth don't have very much.
    If rain falls somewhere else, it will not necessarily be in the right place for crops, direct consumption or other uses. If the best climates for agriculture move poleward, they may not line up as well with suitable soils, water supplies, and all the infrastructure. Some diseases clearly follow climate, and just recently you may have read that river flooding can trump climate change in that regard.
    Humans are a unque species on earth because they depend on all these things. Cognition, agriculture, indistry and civilization are all dandy; they have allowed us to become 'Kings' and to populate much beyond what hunter/gathers could do. Not to mention all the gadgets...
    But still we are uniquely dependent. The risks of climate change on all that remain highly disputed, and perhaps fairly so: We just can't yet pin the details down to everyone's satisfaction.
    So in the main it's 'business as usual'. Small increases in energy-use efficiency, small entry of renewable energy into the mix, and small efforts to sequester carbon in a variety of ways. So the infrared-absorbing gases increase, and we are effectively betting that this is for now the best course to follow.
    Maybe it is, and maybe not. If it's not, then we can only hope to awaken to reality before adaptation and migitation become much more expensive.
    If it is the best course to follow, then thanks will indeed be due to the fossil fuel industry and their friends for steering a steady course.
    Speaking of which, that first oil gusher in Pennsylvania started a global revolution that arguably saved several whale species from extinction. I'm not sure we've properly thanked them for that.
    James Hansen paints a much gloomier picture for the long term. But we'd better approach this a step at a time: what are the largest (and/or most reasonable) steps we ought to be taking this decade? Next decade, ask again, ideally with fuller knowledge and insights. And so forth...
  14. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  15. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    I like your questions FL, but have no answers yet.
    Re: O2, anything less than 19.5% is considered O2 defficient from safety perspective. We need full amount 21% if possible. Never heard anyone say burning fossil fuels could reduce O2. Maybe even increase O2 is the correct answer? Due to photosynthesis of the very high CO2. Don't know. See Wiki "atmosphere", O2 has been all over the place until it lined out at 21%. The atmosphere has a mass of about 5×10E18 kg. So put that in your pipe and smoke it. :smokin:
    You can get estimates of how much fossil fuel burning is expected to 2050, and you could extrapolate.
  16. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Calculations (by me...so could be wrong...pls advise):
    World Population = 7 Billion (this month!)
    Crude Oil Use = 0.5 Gallon per person per day
    Crude Oil - Total Supply = 18250 Gallons per person = 3000 x 10e9 Barrels
    Crude Oil - Total Supply - Burned today = O2 depleted from 20.9 to 20.65 vol%
    Crude Oil - Total Supply - Burned today = CO2 increase +175 ppm
    Re: CO2, this equates to +1.75 ppm CO2 per year, since we currently burn ~1% of the total projected crude oil supply per year. I did not account for CO2 disappearance reactions (per Chogan's article).
  17. tochatihu
    9,852
    3,814
    2001 Prius
    All of the current fossil fuel burn (including oil) is now 8 to 9 petagrams of C. Half of that remains in the atmosphere and the other half is biologically sequestered (at land and sea). The current atmospheric CO2 increase is 2 ppm per year, now slightly more I think. Would need to get the most recent data from Scripps CO2 web site
    So wjtracy estimate for crude oil alone seems too high.
  18. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Thank you, but I am only calculating CO2 released by burning.
    I have no idea how much gets converted back to O2 by plants etc.
    If you say 50% CO2 disappearance, then oil contributes +350 ppm CO2 total
    If you say oil = 1/3 of fossil fuel = then 350x3 = +1000 ppm total CO2
    This seems in general agreement with Chogan.
  19. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Tochatihu- Thank you, you are correct I was off 4x too high, divided by O2 volume instead of Total air volume.
    Here are fixed numbers:
    Crude Oil - Total Supply - Burned today = O2 depleted from 20.9 to 20.65 vol% (250 ppm O2 consumption)
    If you say 50% CO2 uptake by Earth, then oil is approx. 0.8 ppm CO2 increase per year. This should be close enough for government work. :D
  20. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    Since my name was included, I thought I might as well respond. Six seems to be as high as any legitimate scientist seems to put his finger on, this number is from Hanson. It is also a larger range than the IPCC includes. Think Progress seems to often play fast and loose with the facts. Alley has done a comparative analysis of the various historical modeling and has come up with a proxy data number of 2.8. Certainly there is a great deal of uncertainty on the feedback and even the feedback mechanisms, but multivariant analysis needs to be done on historic proxies.
    This does bring us to the OPas question, if we burn everything easy to burn, what will CO2 do. IMHO negative feedback will kick in at some point, but this point won't happen without a large number of natural disasters. Certainly as all the artic ice melts and methane is released, the positive feedback will be reduced as there is nothing left to be released or end reflection.
