Glovebox won't shut
Discussion in 'Gen 2 Prius Main Forum' started by ADDvanced, Aug 31, 2016.
  1. ADDvanced
    ADDvanced Junior Member
    24
    Madison, WI, United States
    So my lower glovebox won't stay shut:
    Any known fixes? Tried searching but found nothing.
  2. ETC(SS)
    6,953
    Your info says it's a 2004.
    I suspect if that's true then either there is a broken bit or the door is warped.
    It's a 12-year-old car.
    Me?
    I'd buy a few pieces off of eBay or Amazon....or use the duct tape.
    kenoarto likes this.
  3. JC91006
    16,672
    8,518
    Looks like the left side is off it's support. It's on the bottom left side of the glove box......you can easily slip it back into the support bracket
    WilDavis likes this.
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Second what JC said. Open the glove box, remove the damper on the right hand side and reseat the box on all of the hinges, then close it and see if it looks better.
    Sorry I don't have a picture for you.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Sometimes I'll accidentally overload mine to find that it won't close easily, then find there's something standing slightly proud and interfering with the way the lower section closes. Re-pack the lower chamber - (works for me every time! - although YMMV) ;)
  6. ADDvanced
    24
    It's definitely the latch mechanism. I took three screws out of it in an attempt to remove it to diagnose the issue but I can't seem to get it out.
    After looking at eBay auctions it seems there is a fourth screw behind the silver panel to the left of the glovebox. Anyone know how to remove that?
  7. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Follow this video to remove the glovebox. From there you should be able to inspect what is wrong. To me it looks like one of the back tabs somehow came out of where it should be with the way the left side of the box is.
    (Also good time to change cabin air filter if you need it...;))
    #7 Kevin_Denver, Aug 31, 2016
    valde3 likes this.
  8. ADDvanced
    24
    Yeah it wasn't that. I found a video to remove the stereo/screen in the prius, so here's what I had to do:
    - Pop out the lower kick panel in the center of the dash, with the cigarette lighter
    - Pull backwards on the silver trim piece next to the dash screen that has the vent, that whole assembly pops out
    - This allows access to the fourth screw that holds the glovebox latch assembly onto the dash
    - The spring on the lower latch assembly was broken in half
    - I repaired the functionality with a rubber band:
    This makes the button 'springy' again and releases the latch like it should
    - I then had to bend the metal u-hook on the glovebox upwards a bit, so it fit into the slot
    - Glovebox now works perfectly again. :)
  9. bejczyp
    bejczyp Junior Member
    HU
    I have a slightly different issue, my glovebox works good, but if I press the lock button too swiftly, the button jumps out and drops to the floor. Some little thing has broken in it, but I can't figure out what or how/where to replace it. 2006 prius. Thanks, Peter
