Featured GM announces many new EV's
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by fotomoto, Mar 4, 2020.
  1. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    10 new models coming with the earliest starting this year (Bolt refresh thats finally getting ACC).
    GM reveals 10 new production EVs all at once, with range up to 400 miles - Electrek
    But the biggest news to me is this battery design philosophy:
    The centerpiece of the presentation was the company’s new battery system, dubbed “Ultium,” which will power GM EVs starting next year.
    The battery system is focused on modularity, allowing different types of cells and chemistries to be used in packs ranging in size from 50 to 200 kWh, enabling “up to 400 miles of range or more.” The company committed to producing cells, in cooperation with LG Chem, that reduce the use of cobalt by 70%, thereby bringing down costs.
    Each module will have a dedicated battery-management-system, a move that will allow an individual module to be replaced with a new one, and even to mix and match different chemistries within a pack. The BMS for a module will store a full set of data that can be accessed at the end of its life, facilitating the recycling and re-use of the cells.
    Andy Oury, a lead engineer for batteries, said, “Ultium is going to help us break through the $100 per kilowatt-hour cost curve.”
    Looks like the roots of early development, that gave them so much data and feedback, is bearing fruit.
    hill likes this.
  2. hill
    8,184
    Hopefully they're next electric iteration won't be a compact, but rather more substantial.
    fotomoto and bisco like this.
    49,490
    Not counting the stupid hummer
    Gm holds dog and pony show for investors, stock up 87 cents (y)
    #3 bisco, Mar 4, 2020
    m.wynn likes this.
  4. hill
    8,184
    You may break even yet!
  5. El Dobro
    El Dobro A Member
    6,979
    3,214
  6. mikefocke
    3,699
    1,645
    Sanford, NC
    It is all hype until it is on the road and proven over thousands of cars and thousands of miles.
    Still a move in the right direction.
  7. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Better hope for a long warranty on the battery cause this seems like a plan for early battery failure.
  8. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    A modular battery like it seems to note means you do not need to match cells. That would be awesome rather than playing the cell matching or balancing game....
    moto g(7) power ?
  9. Trollbait
    11,560
    The VW BEV platform was designed to use different type of cells, and Model #'s in China are using different cells.
    GM's system is dropping pack level battery monitoring and management, and going with stack level to allow the mixing of different types within the same pack.
  10. fotomoto
    5,602
    3,779
    So. Texas
    This is so cool. I'm envisioning future Mad Max movies where the scroungers will be digging through refuse, old electronics, etc., looking for any kind of rechargeable battery to wire into their still running, cobbled together jalopies. :D
    Trollbait likes this.
  11. bwilson4web
    15,524
    I understand this Auto Line After Hours will be a hoot:
    Reporter Roundtable
    Christie Schweinsberg, Wards Intelligence; Joe White, Reuters; Gary Vasilash, AD&P; John McElroy, Autoline.tv
    LIVE March 5@ 3:00PM EST
  12. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    How will they charge in series different cells?
  13. bisco
    49,490
    The magic spell wears off, gm down 2%
  14. markabele
    5,084
    1,782
    Nebraska
    That's not really fair considering the whole market was down.
  15. bisco
    49,490
    i'm just teasing :) but i do suspect the spell will wear off as things drag on. wall street is nothing, if not impatient
    markabele likes this.
  16. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Yikes, seems like several companies are making battery decisions that will come back to bite them in 5+ years!
  17. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    You misspelled their customers. They will be the ones taking the hit.
    noonm likes this.
  18. Trollbait
    11,560
    Each stack/module has a management circuit telling the charge system its cell's requirements. There isn't different cell types under the module level.
    In addition to making the use of different cells easier, GM's system should make repairs easier, as a replaced module doesn't need to be balanced against the rest of the pack, which can take days with a large pack.
  19. bisco
    49,490
    elon probably can't sleep
  20. bwilson4web
    15,524
    Just finished my review:
    • Nickel Cobalt Managenese Aluminum (NCMA) vs Tesla Nickel Cobalt Aluminum (NCA) - we'll need samples for testing. Tesla 2170 cells are readily available
    • wide coating of electrodes - they claim economies of scale, once the battery plant comes online but the larger the cell, the greater the risk of spoiling the whole with one defect
    • smallest number of the largest cells - which means one cell failure leads to a bricked car. Those of us with Prius experience know how a single cell failure leads to cascading set of problems and a bricked car in 3-6 months
    • 100 Ah cell - @3.7 V, 3,700 Wh per cell, putting all your eggs in one basket
    • 20 layers per cell - one bad roller and a lot of scrap
    • flat bottom (long edge) connected to cold-plate - this suggests there will be a significant thermal gradient which means a mechanical strain between the cold plate and far edge. In our Model 3, the cells are warmed to ~50 C for charging but cooled to ~30 C for operation. The Tesla thermal gradient is from the rim to the core which significantly reduces the thermal, mechanical strain.
    • zeolite - an ion holding material whose role is not explained
    • Bolt EV battery comparison - 25% weight reduction, 50% fewer connections, a GOOD THING
    • vertical integration - a GOOD THING, GM is not outsourcing the critical technology
    What was omitted:
    • Corvette EV - a Tesla roadster, Taycan, or Mach-E competitor
    So here are a couple of images:
    Here are three GM different pack configurations showing GM's approach. Notice the inconsistent "modules" from the three pack configurations. But this is what 'raise my eyebrows':
    They have a center 'tunnel' of battery cells, not their 'module', to replicate the legacy drive shafts that screwed up cars since forever. DUMB!
    A reporter/editor from Electrek, a Bolt owner, attended and verified from multiple sources that they are sticking with a 50 kW maximum DC charge rate. Owning a 50 kW maximum, BMW i3-REx, it means they are doomed to roll around urban areas. To go cross country, you need a minimum of 100 kW or the charge time makes highway travel impossible.
    #20 bwilson4web, Mar 5, 2020
    telmo744 likes this.
