GM exec confirms that this cat is out of the bag
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DeadPhish, Oct 14, 2010.
  1. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    There has been a lot of anticipation and speculation on the Volt over the last 5 yrs. In general GM seems to have made all the right decisions to bring a very capable plugin to market on time.
    OK the price is very high. The market will resolve that issue.
    Electric vehicle or hybrid vehicle. Semantics. In 5 yrs no one will care.
    Gas-free range. 40 miles does seem to be the upper limit at this time with the technology. As expected outside influences and driver behavior will affect this capability. We all knew that from our own experiences in the Prius'.
    However, the issue of fuel usage after the battery was depleted was always a question mark. The Volt proponents have been saying during the last 2 yrs that in CS-mode the Volt would be Prius-like @ 2 gpc ( 50 mpg ).
    Now that independent testers actually have the vehicles in their hands for testing the truth is coming out.
    In a statement to the press today a Mr Dave Parks of GM who's in charge of the electric vehicle program confirms what others like Popular Science are finding. Mr Parks confirmed that his own Volt, used for commuting, gets mid-to-high 30's 'in gasoline only mode' ( interesting choice of terms ). This vehicle is not a competitor for the Prius. It's a competitor for the Corolla.
    2 people like this.
  2. Tideland Prius
    16,153
    So basically you better make use of the battery pack and get use to charging every night (if you do use the 40 miles every day) to get the most out of it. So is GM gonna try and use the averages then? (On average, it will use 50mpg but only if you count the EV distance too!). Has any of the articles mention how it does on the highway (where I presume that's where the engine will run b/c the driver is on a long trip with the family).
  3. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    What does that mean????? I don't get what alot of people in the forum are talking about when it comes to the volt.
    Corolla goes 0 inches on battery power. Volt 2,500,000 inches on battery power. How in the hell are you coming up with them being competitors?
    The Volt will compete with the Prius , Leaf, and Insight.
  4. DeadPhish
    2,010
    353
    Fuel Usage...NY to Miami..~1300 driving miles
    Prius G3 @ 2.0 gpc ( 50 mpg ) uses 26 gal of fuel each way
    Prius G2 @ 2.1 gpc ( 47 mpg ) uses 27.2 gal each way
    Volt for 36 mi is gas-free using 0 gal, then
    ......for 1264 miles @ 2.7 gpc ( 37+ mpg ) it uses 34 gal each way
    Corolla @ 2.7 gpc ( 37+ mpg ) uses 35.1 gal each way
    In terms of fuel usage for longer drives the Volt is much closer to the Corolla than to the Prius or Insight II. The Leaf can't get from NY to Miami without riding on a train.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    At $US 41k before taxes etc, the Volt will not compete with anything.
    4 people like this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    As some one who has walked 2500 miles one year, you certainly can drive a Volt or Leaf from NY to Miami without using gasoline, it is going to take you longer, much longer in the case of the Volt.
  7. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    Not true... If it is sitting at the top of a VERY large hill, it will go further than a volt and still leave you with $22k in spare change.
  8. adamace1
    1,403
    191
    Charlotte, NC
    Ok so for long trips, and over 1,000 miles is pretty long i get what you are saying. So for people that drive short trips say 18 miles to work and 18 back the volt burns no gas, and the Corolla burns 1 gallon.
    Anyways i do think alot of people will be looking at the Volt, prius, And the Leaf and they will chose based on their needs.
    Leaf great if you never want to go over 100 miles in your car, or wont get stuck in bad traffic jam in 100 degree plus weather.
    Volt can only go 40 miles on pure electric(enough range for most people) , then you can burn gas to go as far as you want.
    Prius plugin can go 13 miles on pure electric, then gurns gas.
    So eveyone can test drive and make the pick thats best for them or what they enjoy the most.
    I hope all of them do good. i\I'm even sad to see the Insight not doing good. I want all car companies to build more cars like the Prius, Leaf, and Volt!!!!!!
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Considering this $41k hybrid runs on premium gas, that kind of sub-standard MPG shall raise Range Extender Anxiety. The fear of using premium gas is especially pronounced when the real-world EV range can be as low as 25 miles!
  10. SageBrush
    11,627
    2,530
    Southwest Colorado
    Wait till winter arrives and they turn on the heater. The acclaimed "40 EV miles! advert" is going to become 20 miles in real world. Not to worry, though. Whoever buys a Volt is immune from reality.
    2 people like this.
  11. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    If you are commuting 1300 miles you have another problem all together.
    The Volt is for daily commuters, 40 miles each way or less. For them the Volt may use the least gas, tied with the Leaf.
  12. hampdenwireless
    1,104
    86
    Baltimore MD
    While the Volt is sucking on both price and CS mpg, the range is not seeming to be a problem. People have received pretty good range even with the AC on and doing high speeds. The heater is not going to bring the Volt to 20 miles, and I doubt that it will bring it below 30.
  13. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    The compact size Volt does not have the EV range like the real mid-size electric car (Leaf) that costs $8k less.
    The compact size Volt does not get hybrid-like MPG like the real mid-size full hybrid (Prius) that also costs $18k less.
    Why pay more to have the worst of both worlds?
    If you pay more, you should get the best of both worlds. A smaller car should have more EV range or higher MPG.
    3 people like this.
  14. bisco
    49,470
    if it can cover the average commute, and they can make the price competitive, and it is as roomy and practical as prius or leaf, they may have a competitor.
  15. SageBrush
    11,627
    2,530
    Southwest Colorado
    Time will tell. Gentlemen's wager ? Winner picks their coffee or tea of choice.
  16. SageBrush
    11,627
    2,530
    Southwest Colorado
    To paraphrase a saying: if my grandmother had wheels she would be a bus.
  17. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    40 miles is for typical commute round trip. This was the actual question to the survey. On a typical day, how many miles one-way do you travel from home to work? If you add up all the percentages to 20 miles one way, you'll get 78%.
    See the survey GM used to come up with that 75% of the trips "without a drop of gas". I put it in quotes because it is not true. The gas engine needs to run every 6 weeks (engine maintenance light will come on). You'll need to burn the entire gas tank once a year (fuel maintenance light will come on). Note, the report is 7 years old.
    If you can charge at work, 15 miles PHV Prius would cover 68% of all the commute using electricity. The idea is to charge often and avoid paying extra for the battery.
    If you accelerate hard or drive fast, you will use some gas. That's the beauty of being a hybrid. You get to use both power sources when it is suitable. You actually get to use what you paid for (both gas and electric).
    Source
  18. SageBrush
    11,627
    2,530
    Southwest Colorado
    Nice graph, but utterly useless. The cars are not given out randomly, but are bought by people who fit the car's best use and profile. And least the rational buyers, that is.
  19. Tideland Prius
    16,153
    You do realise that we're arguing over small details, right? If anything, the consumer wins. (and the manufacturers do... partially).
    Think about it... We now have the choice of 3 models instead of 1 from 3 diff manufacturers.
    Do you want EV, PHV, or w/e the Volt is? Do you want 14 miles, 40 miles or 100 mile range? Will you take long trips with the car or do you have a separate vehicle for that?
    From my POV, I think we should be privileged that we have these choices and that we can vote with our wallet. The manufacturers win because they're not shouldering the cost of all 3 possible options of blending electric and petrol.
    3 people like this.
  20. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    If the Volt were priced at the 30k range the rest are, it would be a good addition to our choices! However GM priced it right out of the running, you don't even get leather for 41k? Prius, Leaf, Ford and Hundai products will leave the Volt a short lived curiosity!
