GM stops production of Malibu Hybrid
Discussion in 'GM Hybrids and EVs' started by zenMachine, Jun 11, 2009.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    General Motors Corp. has pulled the plug the hybrid-electric version of the Chevrolet Malibu sedan for the 2010 model year due to slow sales that has led to a backlog of inventory of the vehicles on dealer lots.
    A GM spokesman said the company made the decision because of a "sufficient stock of 2009s," and said starting up production in the near future is "possible, but not likely." The company will continue to make hybrid versions of the Malibu for fleet buyers, but it is uncertain if GM will ever produce the Malibu hybrid for retail consumers ever again.
    GM Pulls Plug on Hybrid Model - WSJ.com
  2. hill
    8,187
    So even in the midst of reorganization, the 'spin' continues. "Sufficient stock". Uh, is that the same as saying, "This stuff aint sellin' to save our life" ??
    Hopefully that won't be the new reorganized GM success slogan.
  3. Jimmie84
    Jimmie84 New Member
    1,074
    77
    Minnesnowta
    Don't bother me. I'd never buy a hybrid anyways.
    If I was in business and saw that sales were lacking on a certain vehicle I'm manufacturing, And there is zero demand for it. Why not dump it and move on?
    Chevy sold 64,363 from the early part of the year through May, And only 2,142 of them were a hybrid version.
  4. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    The government agreed to purchase 2,000 as part of the bailout. Based on the drastic spike in Malibu numbers, May could have accounted for 700 of them.
  5. Midpack
    Midpack Member
    461
    43
    Chicagoland
    But the Volt is going to turn them around when they can't sell a hybrid? Make sense?
  6. Rakimb17
    Rakimb17 Junior Member
    48
    Palmdale CA
    I didn't even know the had a malibu hybrid! Not that i'd buy one. I haven't liked the Malibu since the were called Chevelles. :)
  7. patsparks
    10,664
    567
    Adelaide South Australia
    and you are on Prius Chat because?
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Probably to enjoy our collective charm and intellect. ;)
    Tom
  9. patsparks
    10,664
    567
    I suspect he secretly wants one but isn't tough enough to go against the jibes he would get from his Neanderthal work mates in the shelf packing section of Wall-mart.
  10. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I think the issue with the Malibu Hybrid , was they called it a Hybrid. If it was the standard vehicle Malibu, all Malibu's like this, with a small battery and maybe an optional big battery (the size they used), I think the Malibu (stealth hybrid) would have been a great success. The low production volume made the Malibu Hybrid too expensive, with an increase in cost similar to a Prius, for about 1/3 the functionality and 2/3 the maintenaince cost reduction.
    And as Jimmie indcates - the FUD marketers have had an impact.
    By not calling the Malibu Hybrid, a Hybrid, but just a Malibu with a auto start/stop, and made all the Malibu's that way - it would have sold just fine - better? - and cost dramatically less.
  11. Paul79UF
    Paul79UF Junior Member
    27
    Orange County, CA
    The car looks nice, but I can't get over the fact that the bumper has to be dropped just to replace a headlight bulb. At least on the regular Malibu.
    I helped a friend do it. What a PITA.
    The manual said "see dealer" for service.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The manual for changing a Prius bulb is the same. Drop the bumper. But you can just reach in there and replace it if you know what you're doing.
  13. El Dobro
    El Dobro A Member
    6,979
    3,214
    Ask a Chevy tech, I'm sure they would find a way around it to cut the time.
  14. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    Why is this zombie thread resurected. GM simply discontinued one mild hybrid system and went with the malibu e-assist. They didn't kill it, but it is nowhere near the efficiency of the 2013 camry or fusion hybrid, it does not even make it to the cvt altima.
    Compare Side-by-Side
    always with epa figures YMMV, and publications like consumer reports have driving habits that give a much lower mpg boost to hybrids. With in hybrids CR only gets 1 more mpg in the fusion than the camry, and this is dependent on driving - city (fusion advantage) or highway (camry advantage).
  15. El Dobro
    El Dobro A Member
    6,979
    3,214
    Looks like it was only resurrected to complain about a bulb.
  16. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Yep, you are right about that one. I didn't drop the bumper and struggled for an hour and a half trying to reinstall the drivers' side headlight. Finally, got it done.
    Next time, I'll depower the air bag circuit, remove front bumper cover, and replace the burnt out light assy.
    DBCassidy
  17. Hell's Guardian
    Hell's Guardian New Member
    Brazil
    I really don't understand why GM almost always does the wrong move regarding hybrids, altough I like the Volt.
  18. Trollbait
    11,561
    GM's issue across their line up appears to be weight. They know they have to cut the bloat, but that doesn't help current models.
  19. dbcassidy
    1,581
    290
    Vehicle weight is a big concern. When will GM get it?
    DBCassidy
  20. Trollbait
    11,561
    They already have with investments in aluminum manufacturer. GM holds a patent on a welding process that means less non-pass welds. The traditional solution was rivets that added weight and reduced the recyclibility of the aluminum.
