GM wants a 230MPG rating from the EPA
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by markderail, Aug 11, 2009.
  1. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    **2 Similar Threads merged, so there may be some confusing transitions from post to post. --evan
    From CNN (so, that means it's official now?) :
    Chevrolet Volt's official fuel economy: 230 mpg - Aug. 11, 2009
    Chevy Volt to get 230 mpg rating
    Ultra-high mileage for GM's electric-drive Volt could give it a marketing boost.
    From AutoBlogGreen:
    GM announces... 2011 Chevrolet Volt will get 230 mpg city! — Autoblog
    The biggest bombshell is Henderson's announcement that the "230" marketing campaign floating around for the past week is related to the Volt. The EPA has released a new methodology for determining a draft fuel economy standard for extended-range EVs like the Volt, and under this new procedure, the Volt will have a composite urban fuel economy rating of 230 mpg!
    Viral marketing logo !
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    But it has a 1/6 gallon tank, right.;)
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    The EPA has previously given all-electric mileage using a kWh per 100 miles figure. If you look up a RAV4 EV you will see an original sticker of 27 kWh/100mi city, 34 kWh/100mi highway. These have been converted to 'miles per gallon gasoline equivalent' of 125 City, 100 Highway.
    I don't see that the Volt, or any other plug-in hybrid, should be any different. Give the electric part in terms of miles per gallon gasoline equivalent, and the gas part in actual miles per gallon - and list them separately so there's no confusion.
    4 people like this.
  4. Zythryn
    Zythryn Senior Member
    6,283
    4,282
    Well, if they are simply taking into account the gas used and not the energy from electricity, the Tesla's, Leaf and other electrics get an infinite mpg rating, right?
    Infinity/230 is zero, so the volt still fails when it comes to all vehicles, does great with 50 mile drives vs other gas using vehicles though;)
  5. Chrome
    Chrome New Member
    138
    Just fantastic. 25KWh/100miles is great. 230mpg is certainly a headline grabber. I can't wait to buy one!
  6. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    Chevy Volt - 230MPG EPA City?
    Chevy Volt To Get 230 MPG City Fuel Economy Rating - chevy volt - Jalopnik
    Call me a Prius fan, but I think even the most hardcore GM fan would question this EPA rating. Makes sense if you just do city driving, but it seems funny that assuming there's a 11 gallon tank (don't remember the size in the Volt) that you could go 2,530 miles.
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Re: Chevy Volt - 230MPG EPA City?
    How do you measure MPG on the Volt? Isn't your MPG infinity, or undefined, if you never drive beyond the range of the battery charge? I wonder how the EPA is rating it. If it can go 40 miles on a charge and the EPA test lasts for 41 miles, yes, it will have a very high mileage rating if you divide the 41 miles by the gas used for the 1 mile.
  8. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    The formula they use has to be taking "typical user driving patterns" into account. Basically, they assume you drive X miles a day and charge every night. It will vary wildly based on you real driving patterns. If you drive 60 miles a day in the city instead of 30, you will get very different results.
    But, all the plug-ins will have the same issue. However, the plug-in Prius will probably not vary as wildly, but only because it will have a much smaller electric range. Therefore the difference between traveling 35 miles and 55 miles won't make much difference on the Prius, because you were running on gasoline after the first 8 or so miles. However, the difference on the Volt will be huge because with 35 miles, you were using only electricity, but with 55 miles, you used gasoline for 15 miles.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Hmmmm.
    So, Toyota Prius = bad
    At least according to Bob Lutz and other fools at GM who ran the company up on the rocks.
    Now that Government Motors Corporation is sucking on the taxpayer teat, the mythical Volt may become reality. And according to the GM fanboys, Volt = good
    Whatever ....
  10. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The other fraud here is that the Volt will get about 30 (my estimate) MPG when running on gasoline (after the first 40 miles). In my driving I would be lucky to average 35 MPG with a Volt and I manage 46 in my Prius (lots of long highway trips).
    JeffD
  11. Mike Dimmick
    963
    247
    Reading, UK
    Actual fuel economy when gas engine is running: 22.3mpg.
    Working: 230mpg is 0.00434 gallons per mile. That means 0.1926 gallons are consumed over the EPA test course of 44.3 miles. Divide that by the 4.3 miles that the gas engine is running to get 0.04479 gallons per mile. Take the reciprocal (1/x) to get miles per gallon: 22.325 mpg.
    This isn't surprising given the inefficient engine chosen as the range extender and the inherent losses of the generator->motor transmission path.
  12. Politburo
    Politburo Active Member
    971
    208
    Complete speculation and guessing follows.
    I guess this is the standard city test, which would normally result in infinite MPG for the Volt (as described by GM). However the city test starts with a cold engine, and I would guess that the Volt has similar warm-up cycle that a Prius has. 230 mpg therefore is the 11 mile test run divided by the gas used during warm-up. If my guesses are correct, roughly 0.05 gallons were used during warm-up. As a sanity check, anyone know how that compares with the Prius?
  13. snoctor
    snoctor Member
    126
    27
    Davis, CA
    The 230 mpg figure is an eye catcher but doesn't nearly tell the whole story. The EPA needs to come up with a calculation for total energy used to account for the electricity and/or fuel burned on the upcoming (and current) electric cars. You noticed that Nissan didn't announce that the Leaf would get infinite mileage because the car does use energy.
  14. rfruth
    rfruth Member
    394
    Houston, Tx
    Saying the Volt will get in the triple digit range is probably more like it
  15. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    buy one? WE (American taxpayers) OWN GM, now, don't we? We should be receiving our GM Volt any day now, free. Of course the billions we've already paid them wasn't free. hmm...who's getting screwed here? Oh and to add to the sarcasm...isn't a MPG rating on a non-existent car zero? wake me when there's one of these Volt thingies for sale...to me...the part owner of a delirious, marketing ploy car company. wow, this gets old...talk and press release after talk and press release. spin. repeat.
  16. hill
    8,253
    You mean "the other fraud" in the sense that GM doesn't even build the car that they've been talking about now for what ... two years? I wonder if this talk will go along as far as hydrogen cars have made talk ... some 35ish years or more. So build it already! The battery technology isn't quite ready? Oh ... so how do you explain the RAV-4EV's running around (the ones that escaped the crusher) that have over 100,000 miles
    :rolleyes:
    3 people like this.
  17. Chrome
    Chrome New Member
    138
    I don't think that figurin' is the right way of doing it. You're making certain assumptions. Also, what would the MPG of the Prius be on the EPA's course if the gasoline engine was on all the time? We can't know that.
    Who said the Prius was bad? It's not a very involving or attractive vehicle, but it serves its purpose extremely well. Can't really fault it for that.
    The Volt was well on its way to reality long before we gave GM any more.
    So, should the Japanese, Californians, Mississippians, and Kentuckians all get free Priuses since all of those governments have either given direct aid (Japan) or massive tax breaks to Toyota at the expense of tax payers?
    What are your views of the Nissan Leaf? That only exists in press releases. Is Nissan a delirious, marketing ploy car company, too?
  18. Mike Dimmick
    963
    247
    Reading, UK
    My post on the other 230mpg thread:
  19. Chrome
    Chrome New Member
    138
    They've built/are building several dozen as we speak. They are already on the road for testing. There are photos and videos of the assembly process and of the test drives.
    Jeez.
  20. finman
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Well, until a vehicle materializes for me to purchase, it's only fun to follow the press releases. I'm an optimist for Nissan. Not so for GMs future. The showroom is where the real world product is needed. The waiting is the hard part...since I've been driving the "future" now for 5 years and counting. a bit of sarcasm. or not.
