Going away for a month. How to leave my Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, Nov 21, 2014.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I'm going out of the country for about a month. I was wondering if I can just leave the Prius like regular car. Any advice/ suggestion?
    51,155
    i do, but it's never more than 5 years old and the 12 volt has never been run down. that's the only thing to be concerned about. it's small and weak, and if it's older or has been run down from leaving a light on etc., you may want to get a battery tender.
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Can I just disconnect the battery and leave it like that?
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Pointless.
    IF your battery is healthy and it is fully charged when you leave, it should be fine.
    If it is NOT healthy or is low on charge, disconnecting it won't help anything.
    A small automatic tender-type charger can be had for about $35.
    Connecting one of them is good, if you can.
    Having a small charger is good in general.
    P.S. This subject has been discussed to death on here previously. A search should yield a LOT of information and opinions.
