2021 Prius. A little later this year I have to go overseas for three months. I can (1) park the car up and disconnect 12V battery or (2) have someone go to the car once a week and put in Ready Mode for 30 minutes or so (so it runs the engine and charges 12V battery). Which is the best option? Ideally I'd have someone use the car regularly, but got nobody who will do that......
running it is better, but sometimes people forget. i would park it with a fairly full battery, disconnect the 12v or put a maintainer on it, and pump up the tyres to prevent flat spots
Since the battery is easy to get to on this one. Put a smart RV battery maintainer on it and wrap the power cord around your driver's side mirror - do you don't forget to disconnect it when you get back. If you don't have a smart RV battery maintainer, just disconnect the negative battery cable on the car. Once you do that, the FOB and alarms won't work. You'll need to use the aux. key to lock and unlock the car. Hope this helps.....
